  1. With gspot i have read the codec name of a video, which is MPEG2_Video(MPEG2). In Virtualdub, I am inputting an avs script which reads an mpeg-ps(.mpg) video with filters. I want to ouse the smart rendering option to be able to save the filtered .mpg file as a compressed .avi file, but Virtualdub wont save it because the right codec is not chosen. So which codec decoder/encoder should i use to be able to use the smart rendering option(have tried ffdshow but couldnt find the right configuration)?
  2. .avs frameserves uncompressed video, so smart rendering won't work
    But even if you didn't use .avs , vdub cannot smart render mpeg2
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    "Smart rendering" only works for saving a file in the same format as original, just recoding the changed parts.
    You can use some MPEG editors, like MPEG-VCR, to do that with MPEG.
    If you are converting MPEG to AVI, you can't do "smart" rendering at all.
    Everything must be reencoded.
  4. Which MPEG2 editor is identical to the .avi based Virtualdub program with these features: no crash during rendering, no audio/video sync problems, not to expensive, can work with avisynth filters, has batching features, encoded video quality loss is minimum, has a working smart rendering option, rendering time is pretty fast for a low budget/free software? Should i use MPEG-VCR for this, or do you suggest another program?
    Dec 2010
    quebec
    avidemux may be close ...
  6. I was experimenting with avidemux, but i couldnt import an .avs file into it, and it has no buildin overlay-plugin as far as i can see, is there another way to import an .avs file into avidemux?
    Dec 2010
    quebec
    you've got to mess with AVS proxy GUI (an AVIdemux option) and import your script from that
