    Mar 2011
    Oregon, US
    I Have several avi files that have long names I would like to concatenate them and change the fonts and font size and put them in my menu?
    What is this called ? What piece of software can do this? DVDStyler ? Please put into the right section. John
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Right-click on the file and rename it?
    Or do you mean that you want a menu for the avi files that works on a dvd player? or computer? or what?
  4. @ RBCC
    Not sure either what you are looking for. Something like this http://www.bulkrenameutility.co.uk/Main_Intro.php. Or in DVDStyler you can put any text-button / text-string on a menu using any color/font/size you want
    PS I can see from your previous post that you apperantly is trying to use DVD Styler. To add a text you rightclick the menu, type the text and choose color/font/size. To add a textbutton you click the button tab on your left and choose the button you want and edit it to your liking. And if what you want is to have your filename in the text/button - well copy from Explorer/paste in DVDStyler
    http://www.dvdstyler.org/docs/dvd_styler_guide.pdf
    Mar 2011
    Oregon, US
    Home DVD Player.
