Hello!
I just bought a BluRay Burner for my computer. I would like to create custom BluRay menus where the user can set his subtitles and more (something like GfD for DVDs, or maybe it works for blurays aswell?). What's the best authoring tool according to you?
Thankfull for answers
/michcio
thanks, sorry for not searching better on the forum, I've looked at all the available software. MultiAVCHD was kind of nice, though after I created a custom menu and tried to launch my AVCHD filesystem in VLC the menus got weird (showed only sometimes and if shown, I couldn't click on any menu buttons
) also I didn't dare to take a risk with AVCHD (make a bluray disc which then can't be read by all players :/).
AVCHDCoder was cool as well though it's not possible to create a custom menu in it.
As for now I got stuck with Adobe Encore where you can create manus almost from scratch
(design your own buttons, link buttons etc.) I've got a problem with adobe encore when it comes to subtitles and character encoding though. Just made a post about it: https://forum.videohelp.com/threads/342929-Adobe-Encore-Subtitles-ASCII?p=2136435#post2136435
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 14:03 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37 -
What is a good authoring tool?
By breeze9 in forum Authoring (DVD)Replies: 1Last Post: 26th Jan 2008, 00:17 -
Which DVD Authoring tool to use?
By jodajen2 in forum Authoring (DVD)Replies: 6Last Post: 14th Nov 2007, 09:21 -
Which authoring tool under vista? Some special needs.
By MagicSparky in forum Authoring (DVD)Replies: 3Last Post: 26th Aug 2007, 18:09
