OK....I forgot:
Can I use a SCART to S-VIDEO cable on a non S-VHS machine?
My S-VHS machine just died. I connected my SCART to S-VIDEO cable from my backup VCR to my PVR-350
but got no signal.....HOWEVER....I think that cable was broken anyway. I recall it coming apart the last
time I used it to capture from my TV box.
You will have composite coming out of the S-video luma pin, and nothing coming out of the S-video chroma pin.
If the PVR-350 can treat the S-video luma as composite (e.g. via a software setting), then you're fine. If it can't (because there's no such setting, and/or its physically separate in hardware) then you need a new cable. SCART to L/R/CVBS adapters are very common.
Cheers,
David.
Is using S-Video cable better than using RCA cables to capture video?
By snafubaby in forum Capturing and VCRReplies: 21Last Post: 7th May 2020, 08:16 -
Capture Video/Audio from STB (DVB) with SCART in W7MCE through USB (EzCAP?)
By DIRKZELF in forum Capturing and VCRReplies: 7Last Post: 16th Jan 2012, 18:10 -
Cable/Fox PC video capture
By frankiecat in forum Capturing and VCRReplies: 4Last Post: 22nd Dec 2011, 00:24 -
Video Capture Device: Cable length question (affects stalling?)
By iwc101 in forum Capturing and VCRReplies: 3Last Post: 18th Sep 2008, 01:09 -
Cable video capture problem
By spork985 in forum Capturing and VCRReplies: 9Last Post: 23rd Dec 2007, 13:59
