Hey guys,
I already posted in two other threads here in the forum. I'm trying to transcode holiday videos for a friend. Whilst I was very happy to find tools like MultiAVCHD and AVCHDCoder which offered all the options and settings I needed (joining of mts files, reencoding as strict AVCHD compliant dvd-9) both tools only transcode with the 32bit version of x264. That leads to a cpu usage of just 30% on my AMD PhenomII sixcore. A forum user recommended I should try RipBot. That tool works fine with the 64bit version of x264 and due to that, I'm able to encode the video media with roundabout 32 fps in contrast to 10 fps with AVCHDCoder or just 1.4 (! - yes 1.4) frames with MultiAVCHD.
Both tools offer me the option to active 64bit encoding in the settings but both tools don't work after activating it. MultiAVCHD just says transcoding failed
and ACHDCoder just uses the 32bit version instead of the x64 version. I even tried to overwrite the 32bit versions with the 64bit versions. That solution led to non encoding at all in both tools.01:30:12] *** Encoding : One pass - content: [00:27:02]
[01:30:12] *** Encoding : x264 options: --preset ultrafast -B 8000 -I 50 --level 4 -i 24 -b 3 -m 0 -r 4 --ipratio 1.4 --vbv-bufsize 15000 --vbv-maxrate 14000 --qcomp 0.5 --threads auto --thread-input --aud --nal-hrd vbr --sar 1:1 --me dia --b-pyramid strict --slices 0 --weightp 0 --rc-lookahead 0 -o "C:\Program Files (x86)\multiAVCHD\_TEMP\multiTEMP-20120119\Aegypten_Sheradon_Soma_Bay.[1280x720-25.000].264" "C:\Program Files (x86)\multiAVCHD\_TEMP\multiTEMP-20120119\20120119-013012-uncrop-running.avs"
[01:30:12] *** Speed : 237169.59 fps (elapsed: 00:00:00 - Realtime x 9486.78)
[01:30:12] *** Transcoding failed!
[01:30:12] *** Check ffdshow/avisynth/haali (reinstall)!
I would be so grateful for an explanation or help!!
cheers from Germany
Closed Thread
Please STOP create new similar threads. https://forum.videohelp.com/threads/342736-AVCHD-transcoding-with-MultiAVCHD-SLOW-(just...age)?p=2135436
Issues getting DVD Shrink to work under Win7-64bit
By Djinn987 in forum DVD RippingReplies: 11Last Post: 30th Oct 2012, 17:44 -
I can't get multiAVCHD to install running win7 64bit
By Onceler2 in forum Authoring (Blu-ray)Replies: 0Last Post: 17th Sep 2011, 21:29 -
Multiavchd:override presets by using custom x264 cli
By lutinor in forum Newbie / General discussionsReplies: 0Last Post: 4th May 2011, 03:53 -
multiAVCHD's x264 always shuts down half way during transcoding
By jones24 in forum Video ConversionReplies: 16Last Post: 14th Feb 2010, 16:49 -
Multiple blu ray titles-No menu with AVCHDcoder or MultiAVCHD?
By thegeeman in forum Authoring (Blu-ray)Replies: 6Last Post: 22nd Sep 2009, 09:22
