Guess it's an already asked question, but couldnt find the correct keyword. Please, forgive this first post of a videohelp.com newbie.
I have some subtitles.
They are synchronized in order to appear when the actor start talking and disappear when the actor has finished.
I wanna extend the display time of each sub line as long as possible, until the next subtitle start time.
I'm using SubtitleEdit, Subtitle Workshop. Or I can use everything. Just thanks for any advice.
In Subtitle Edit you can use Tools -> Adjust durations -> Add one second (or something else) to all durations (it will not create overlapping subtitles)
I sure SW can do the same.
Subtitle Workshop - not creating subtitle at current time location
By botjocrow in forum SubtitleReplies: 0Last Post: 14th May 2011, 03:09 -
Do not display changed subtitle.
By manjularoshan in forum SubtitleReplies: 0Last Post: 8th May 2010, 04:35 -
Subtitle display
By cheerful in forum Software PlayingReplies: 4Last Post: 18th Jan 2010, 20:40 -
Problem expanding subtitle time with Subtitle Workshop
By Kaze105 in forum SubtitleReplies: 1Last Post: 11th Nov 2008, 22:16 -
Delete display of running time
By tonwark in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jun 2008, 12:53
