Hi all,
I was pretty happy with the older version of SolveigMM AVI Trimmer when I used it in XP 32bit, but I'm having too many problems with the latest version in Win7 64bit. I don't know what the problem is exactly, but the trimmed videos it creates will not play correctly in VLC or MPC.
What Solveigmm does is allow you to select multiple scenes in an AVI video, you then save those scenes (spliced together) as a new video. It's freeware, so the options are pretty basic.
So, can someone recommend an affordable alternative?
Avidemux or virtualdub, set start and stop for the scenes you don't want, delete, repeat. Save.
What is the best current AVI to MPEG 2 converting software?
By avz10 in forum Video ConversionReplies: 8Last Post: 2nd May 2012, 17:00 -
Possible to replace two scenes of AVCHD file without long re-encoding?
By mikeveli20 in forum EditingReplies: 20Last Post: 12th Mar 2011, 12:38 -
Replace x264 Encoder with a "CUDA" CLI app?
By Raycaster in forum Blu-ray RippingReplies: 3Last Post: 31st Dec 2010, 03:03 -
How to Replace/Distort Uncensored Scenes in a movie with Blank
By ishopper in forum Newbie / General discussionsReplies: 5Last Post: 30th Sep 2009, 00:54 -
Select Layer Break In Authoring App?
By RABinMS in forum Authoring (DVD)Replies: 6Last Post: 21st Nov 2007, 08:36
