Any suggestions on TransCoding Software ? I'm presently using Prism File Converter. I want to know if there are any other options available, I need to trancode video of any format to the following without loosing any quality. Which of the following codecs below are insignificant and useless ?
Quicktime DV / DVCAM
Quicktime DVCPRO
Quicktime DVCPRO 50
Quicktime DVCPRO HD
Quicktime H.264 (playback performance dependant on CPU – transcode recommended) (What is different about QT h.264 over other h.264, because the video editor won't load other variants of h.264 ?)
Quicktime AVCHD (playback performance dependant on CPU – transcode recommended)
Quicktime Photojpeg (playback performance dependant on CPU – transcode recommended)
MXF OpAtom DVCPRO (P2)
MXF OpAtom DVCPRO 50 (P2)
MXF OpAtom DVCPRO HD (P2)
MXF Op1a DV / DVCAM (XDCAM)
MXF Op1a MPEG-2 SD I-Frame (10Mb/s – 50Mb/s)
MXF Op1a MPEG-2 HD I-Frame (50Mb/s – 300Mb/s)
AVI DV / DVCAM
AVI DVCPRO
AVI DVCPRO 50
AVI DVCPRO HD
AVI Uncompressed SD
AVI Uncompressed HD
AVI MPEG-2 SD I-Frame
AVI MPEG-2 HD I-Frame
AVI MJPEG
These are the following Video and Audio CODECS on my PC. Any of them work with the formats I need to convert to listed above ? Are there any video and audio codecs listed below that are old I don't need, and can delete ?
Video Codecs
ICM Microsoft RLE MRLE msrle32.dll 6.1.7601.17514
ICM Microsoft Video 1 MSVC msvidc32.dll 6.1.7601.17514
ICM Microsoft YUV UYVY msyuv.dll 6.1.7601.17514
ICM Intel IYUV codec IYUV iyuv_32.dll 6.1.7601.17514
ICM Helix I420 YUV Codec I420 i420vfw.dll 1.3.0.0
ICM Toshiba YUV Codec Y411 tsbyuv.dll 6.1.7601.17514
ICM Cinepak Codec by Radius cvid iccvid.dll 1.10.0.13
ICM TechSmith Screen Capture Codec tscc tsccvid.dll 2.0.6.0
ICM Helix YV12 YUV Codec YV12 yv12vfw.dll 1.3.0.0
ICM Lossless RGBA compression LWLR
DMO Mpeg4s Decoder DMO mp4s, MP4S, m4s2, M4S2, MP4V, mp4v, XVID, xvid, DIVX, DX50 mp4sdecd.dll 6.1.7600.16385
DMO WMV Screen decoder DMO MSS1, MSS2 wmvsdecd.dll 6.1.7601.17514
DMO WMVideo Decoder DMO WMV1, WMV2, WMV3, WMVA, WVC1, WMVP, WVP2 wmvdecod.dll 6.1.7601.17514
DMO Mpeg43 Decoder DMO mp43, MP43 mp43decd.dll 6.1.7600.16385
DMO Mpeg4 Decoder DMO MPG4, mpg4, mp42, MP42
Audio Codecs
ACM Microsoft IMA ADPCM CODEC 0011 imaadp32.acm 6.1.7600.16385
ACM Microsoft CCITT G.711 A-Law and u-Law CODEC 0007 msg711.acm 6.1.7600.16385
ACM Microsoft GSM 6.10 Audio CODEC 0031 msgsm32.acm 6.1.7600.16385
ACM Microsoft ADPCM CODEC 0002 msadp32.acm 6.1.7600.16385
ACM Fraunhofer IIS MPEG Layer-3 Codec (decode only) 0055 l3codeca.acm 1.9.0.401
ACM Microsoft PCM Converter 0001
DMO WMAudio Decoder DMO 0160, 0161, 0162, 0163 WMADMOD.DLL 6.1.7601.17514
DMO WMAPro over S/PDIF DMO 0162 WMADMOD.DLL 6.1.7601.17514
DMO WMSpeech Decoder DMO 000A, 000B WMSPDMOD.DLL 6.1.7601.17514
DMO MP3 Decoder DMO 0055 mp3dmod.dll 6.1.7600.16385
I've installed the Avid DNxHD codec but it's not listed ?
Results 1 to 1 of 1
Codecs gone, not showing up in VirtualDub or other software....
By ggouweloos in forum Video ConversionReplies: 19Last Post: 15th Sep 2012, 00:24 -
Are transcoding AV-sync errors caused by hardware or software?
By MarcMiller in forum Video ConversionReplies: 14Last Post: 6th Dec 2011, 16:44 -
Good Free Transcoding Software
By Bob740 in forum EditingReplies: 8Last Post: 8th Mar 2011, 23:24 -
By Prince Valiant in forum Video ConversionReplies: 4Last Post: 11th Sep 2010, 11:26 -
Automatic Video Folder transcoding software ?
By h.264NERD in forum Off topicReplies: 4Last Post: 9th Jul 2007, 12:56
