Want to know if I can open a file under "mpeg tools" in tmpgenc so i can cut the last half of my divx file. I've tried it under virtual dub but the projected file size for the half i want to cut out is about the same size as the whole movie itself! and i dont know it that big ... can i cut avi files the same way i can cut mpeg within tmpgenc?
I cut my AVIs in Virtual Dub.
1. Load file, set audio and video to "direct stream copy"
2. Set the start and end point of the portion you want to keep.
3. Save as new avi file.
4. That's it.
http://www.vcdhelp.com/virtualdubedit.htmAs Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Avi files "Not Support Video" on dvd player?
By aelfheah in forum DVD RippingReplies: 11Last Post: 12th Sep 2011, 13:18 -
need help cutting and joining avi files in virtualdub
By granturissimus in forum EditingReplies: 3Last Post: 31st Jan 2011, 03:53 -
Cutting/Splitting AVI Video Files Software
By Teac23 in forum EditingReplies: 1Last Post: 29th Oct 2009, 07:23 -
After reinstall of OS etc, Tmpgenc encoder can't support avi media files
By AORMan in forum Video ConversionReplies: 15Last Post: 2nd Feb 2008, 11:36 -
Cutting AVI files by frame or keyframe?
By squegole in forum EditingReplies: 6Last Post: 1st Jun 2007, 13:25
