It has to be on a separate line , or use "." to separate the commands
orCode:FFMpegSource2("F:\video\xploratv.mp4", atrack=-1).ConvertToRGB32()
Code:FFMpegSource2("F:\video\xploratv.mp4", atrack=-1) ConvertToRGB32()
BTW I get no errors on that youtube video in Premiere CS4 or CS5, loading it natively as mp4
Results 31 to 38 of 38
Looks like this works. I can load the file in premiere and video looks OK, however, the playback is a little bit choppy. Is it normal?
It will depend on your system specs, but it might be a bit choppy .
The reason is any frameserver will add extra overhead and RGB conversion computation , and MPE will not software accelarate these. It will never be as smooth as a media player
This is one reason why people use intermediates like cineform , which make editing "snappier" and more responsive, the negatives being extra conversion time and large filesizes
Can you recap the solution you used for getting the avfs registering working? In case someone else has same problem as you -
I installed the pfmap-159-win from the link you provided. Once I did it the pmf register worked. pfmap-159-win is the latest file on that page.
I was not sure what pfmkit was, so I took the latesy pfmap. I did not tried pfmkit.
On the front download page, it's http://www.pismotechnic.com/download/pfmap-162-win.exe
pfmap-162-win.exe => I think that's build 162 that might be causing your initial problems ?
and yes, I missed your edit, for HD Footage it should be
ConvertToRGB32(matrix="Rec709")
If it's interlaced (not for youtube, but for future reference)
ConvertToRGB32(matrix="Rec709", interlaced=true)
(SD footage would typically use Rec601) -
thanks, I will save this thread for future reference.
Capturing YouTube videos
By henry33 in forum Capturing and VCRReplies: 5Last Post: 7th Oct 2011, 23:38 -
Youtube capturing
By rjenuzel in forum Video Streaming DownloadingReplies: 5Last Post: 27th Jan 2011, 05:07 -
Mac question: Capturing YouTube from Cache?
By Littlebit in forum Video Streaming DownloadingReplies: 0Last Post: 20th Aug 2010, 18:29 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 14:40 -
Alternative to VIXY.net (capturing from youtube)?
By jerrylynnb in forum Video Streaming DownloadingReplies: 2Last Post: 28th Oct 2008, 12:37
