First post here guys. Have a question about creating a blu ray from a mkv or mp4 file. I'm using Leawo Blu ray creator software to author the blu ray and also burning. Program really doesn't have many advanced settings, i can't choose fps.... Once I burn the movie and play it.. it starts out ok but the longer you watch , the more it starts to get out of sync. Until soon it's a couple seconds off. I'm not really sure what I'm doing wrong. I feel as if it has something to do with the frames per second or something. Just not sure. Any suggestions would be helpful. If anyone know's of any better programs to use feel free to throw that into as well. Freeware or not.
Results 1 to 11 of 11
ok...... i got avchdcoder, installed and tried to run program.. got process going and it will only go about 5 seconds. Errorcode 0x0401
right after extracting is done. any ideas ? -
That error code indicates you're not properly configured.
You need AviSynth, ffdshow, and Haali, and it's wise to use the specific versions the author of the program has tested. AVCHDCoder has a handy configuration test utility, have you used it?
Pull! Bang! Darn! -
what do you mean needed all three of those programs ? avcdcoder will not take a mkv video and make it into a iso ??? im new to taking mkv to iso. thanks for advice...
That means you'll need to have AVISynth, ffdshow, and the Haali splitter installed (most likely, the versions recommended by AVCHDCoder's author), in order to use AVCHDCoder.
I'm not sure if it'll create an ISO, but it should generate the AVCHD structure you'll need. From there, you can just burn/write it to a disc (or USB flash drive).If cameras add ten pounds, why would people want to eat them? -
ok got all 3 installed and testing if i can get config correct. While doing tester everything passes except the 2nd = VC1 should i change to 64bit or stay at 32? By the way ... you all are being so helpful ! thank you thank you
Sorry, was out for the weekend.
Unfortunately, I don't use AVCHDCoder, so I probably won't be of much help. But it's probably a 32-bit program, for the most part, so chances are, you should keep everything 32-bit. (Unless I'm misunderstanding something that's a function of AVCHDCoder...)If cameras add ten pounds, why would people want to eat them?
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 21:34 -
Is it possible to watch Blu Ray movies on your HD TV using your...
By pwangdel in forum Software PlayingReplies: 2Last Post: 2nd Nov 2008, 17:46 -
Blu-ray is no longer Fony's key to winning the format war
By NICEBUD in forum Newbie / General discussionsReplies: 39Last Post: 18th Jul 2008, 19:27 -
Web page for Guide for MKV to Blu-ray no longer works?
By dwisniski in forum Authoring (Blu-ray)Replies: 8Last Post: 10th Jul 2008, 21:44 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 16:05
