I have an Oppo BDP-93 and it apparently plays MKV files. If I have one and want to put it onto a disc, I've been told I can just burn it as a data disc (Blu-Ray) and that the Oppo should recognize it. Is this correct? I'd hate to have to convert the file as that defeats the purpose of having an MKV to begin with.
What type of data disc would I burn it with. I'd be using Toast 11.
You might want to first try simply burning it to a single or dual layer standard DVD data disk. You could use either Toast, Burn for OSX, or even the Finder or Disk Utility. Burn would be my personal choice for a data disk. If it has to be put on a BluRay, I'm hoping there is a data archive option in Toast where you can click the little dropdown to choose the media type as BluRay. What kind of BluRay burner do you use with your Mac out of curiousity?
The file would be bigger than what a dual layer could hold
I actually don't have a Blu-Ray burner for the mac yet, but I am looking into getting one soon here -
There are no guarantees if you just burn a downloaded MKV file that any DVD player, BluRay player or streaming media player will play it. More and more MKV files are using "stripped headers" and I'm not aware of anything except a PC that can play those. "stripped headers" is kind of becoming like GMC is in Divx where for a while some dumbasses were incapable of recording in Divx without using 3 warp point GMC and as far as I know we still don't have anything but PCs that are able to handle it. There are a few other encode options in H.264 video under MKV that can be problematic, but I don't remember what those are off the top of my head. Those are less common than the stripped headers thing is.
You might want to keep a re-writable BluRay disc around for testing with. -
Test on a USB flash drive.
BD-RE's are indispensable for testing while you're getting your BD workflow down. -
It'll play the mkv off disc or usb, even over dlna, provided it supports the codecs inside.
FYI a good FAQ about the Oppo, http://watershade.net/wmcclain/BDP-93-faq.html
There's a section on media files if you scroll down a bit.
Put NBC's Ed on Blu-ray!
Oppo BDP-93 region hack
By Gabriel in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Jan 2011, 15:13 -
new cheaper $289 Oppo BDP-80 Blu-Ray player announced
By edDV in forum Latest Video NewsReplies: 4Last Post: 6th Jul 2010, 10:59 -
Anyone going to buy the new Oppo BDP-83 Blu-ray player?
By edDV in forum DVD & Blu-ray PlayersReplies: 8Last Post: 2nd Oct 2009, 05:59 -
modified oppo bdp-83 region free
By NicholasB in forum DVD & Blu-ray PlayersReplies: 1Last Post: 22nd Jun 2009, 13:35
