I have sony vegas movie studio, and am trying sony vegas pro--rendering file size for mpegs of same 640 X 360 and same 30 fps is double the size of movie studio. Any idea why, and how to fix?
K
Change the video and audio bitrate to adjust the output file size. Probably under export settings and search for bit rate. You can calculate what bitrate to use with a bitrate calculator, https://www.videohelp.com/tools/sections/bitrate-calculators
The frame size and fps does not matter. -
Thanks! I lowered the bit rate to 2mpbs, it worked fine without reducing quality on 640 x 360
Thanks again,
K
Whats is best HD option for rendering with Sony vegas movie studio HD?
By Sevy in forum Newbie / General discussionsReplies: 6Last Post: 17th Oct 2011, 15:57 -
Sony Vegas Movie Studio 10 rendering problem
By videogirl214 in forum EditingReplies: 1Last Post: 18th Aug 2010, 23:29 -
Rendering MPEG 2 in SONY VEGAS PRO 9
By sfalcon in forum AudioReplies: 1Last Post: 21st Feb 2010, 16:07 -
Vegas Pro and Movie Studio Platinum 9 bug (confirmed with Sony).
By The village idiot in forum EditingReplies: 7Last Post: 18th Dec 2009, 15:21 -
Sony Vegas rendering problem. Movies get much larger than estimated.
By Night-Blade in forum EditingReplies: 4Last Post: 2nd Jul 2008, 14:57
