Hi guys,
I want to use TMPGenc to rip my DVDs to DivX?
I want to somehow set it so that the output size depends on the length of the movie so that the quality is consistent. (rather than making them all 700 meg)
Could somebody please fill me in on how to do this?
Thanks in advance![]()
Results 1 to 9 of 9
Which tmpgenc version? Tmpgenc xpress, tmpgenc video mastering works, etc?
But I would guess it's under the video tab and change to 1 pass vbr(constant quality) and adjust the quality setting. -
Are there any programs out there that can normalize so that all movies will be roughly the same volume?
Also, I forgot about the subs (the subs that come up when people are speaking another language).... Is there a way to embed that into the video instead of having a sub file?) -
No, tmpgenc xpress can't add subs. Use DVDFab or some other free dvd to divx converter like autogk, fairuse wizard or handbrake 0.9.3. They can embed subtitles.
I don't know any that can normalize audio. -
Not that I ever used it but I think MediaCoder can (or at least you can set the gain - that I've used
videobruger: How did you fix the attachment? It was just a link first. Something is wrong with the file attachments but I can't find the bug.
Baldrick: Not sure. Tried editing it a couple of times. The picture showed in the edit frame. Then decided to try replacing the picture with a cut-out, ie smaller size but when I backspaced on the picture ... well I lost connection to the site (IE9) and when I came back the picture was there.
Good luck with it
the movie isnt playing with consistency
By timmi in forum Software PlayingReplies: 1Last Post: 11th Jan 2009, 08:16 -
ConvertXtoDVD vs. Tmpgenc DVD Author w/Divx Authoring
By Iron_Monkey in forum Authoring (DVD)Replies: 4Last Post: 21st Dec 2008, 21:00 -
Problem with TMPGEnc DVD Author 3 with DIVX Authoring
By LadyTaz in forum Authoring (DVD)Replies: 0Last Post: 21st Apr 2008, 21:36 -
Adding chapters in TMPGEnc DVD Author 3 with DivX Authoring?
By T_virus in forum Authoring (DVD)Replies: 3Last Post: 30th Dec 2007, 20:53 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
