Hi
I had an .vob file. I converted it to an .avi vith VD-Mpeg2.
Then I wanted to change the audio.
So, I saved the .wav with VD, then edited it with Adobe Audition, saved with .mp3.
Then I wanted to change the audio in my videoclip, so I did "Audio->Browse for audio..." from VD menu, video -> Direct Stream Copy.
Saved as .avi, but right before finishing the job VD informed about an error.
"Audio samples 12379-12426 could not be read in the source. The file may be corrupted."
But the file is not corrupted, everything is OK.
Maybe the reason is FadeFX plugin, which I used while converting the .vob?
Thanks for reading.
Here's the screenshot:
You should have replaced the audio while you were working on the MPEG/VOB.....and don't use MP3.
Load the VOB
Save audio as wav
edit/enhance audio
save as wav
With VOB still open, load new wav file
compress to AVI (with MP3 audio if you prefer). -
Thanks, I've done everything.
But, after all, I want to know, what the reason of getting an error in avi? Can somebody answer?
VirtualDub Error: The audio streams have incompatible data formats
By UMO in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 02:38 -
Error While Encoding Audio On VirtualDub
By ashwin.terminator in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2009, 09:00 -
Error with Xvid4PSP when converting MKV to AVI (VirtualDub Error)
By Peter25 in forum Newbie / General discussionsReplies: 1Last Post: 9th Apr 2009, 18:10 -
VirtualDub 1.8.6 = Error about Audio (VBR) ??
By UmmAddan in forum Newbie / General discussionsReplies: 3Last Post: 28th Oct 2008, 10:55 -
Virtualdub error with DV files - Audio Samples not found in source
By kbehel in forum Video ConversionReplies: 4Last Post: 30th Mar 2008, 03:40
