I'm trying to make an mkv (720p x264 video) into a DVD using MultiAVCHD. Initially AVSinfo was crashing out so I reinstalled Avisynth, Haali media splitter, & FFDshow per the instructions found here: http://adubvideo.net/how-to/setup-proper-playback-chain-windows
That fixed the problem with AVSinfo, but then new problems arose. It wasn't encoding anything sitting there staying at 0% for an extended period of time. I fixed one setting in ffdshow and then it started encoding the first pass. Now it's reading 97.8%, but it's telling me output size of 0MB/GB and the time to completion is doing nothing but going up. Doublechecking the temp & output folders being used, there is no where near 3GB of data in either location. So what am I missing here? I'm trying to make a standard DVD playable on regular players, so I guess I'm encoding mpeg2.
Thoughts?
Log so far:
[12:09:41] *** Initiating video encoding:
[12:09:41] *** Original : 1280x720
[12:09:41] *** Crop : 0
[12:09:41] *** Resize : 720x480
[12:09:41] *** Uncrop to : 720x480
[12:09:41] *** Sharpen : 0
[12:09:41] *** Bitrate : 2971 kbps
[12:09:41] *** Frame rate: 23.976 (29.970)
[12:09:41] *** Profile : SD-DVD (MPEG-2)
[12:09:41] *** Encoding : Pass one - content: [02:48:34] (MPEG-2 encoder: lavc)
[15:23:05] *** Close to completion - closing preview...
[15:39:36] *** Speed P1 : 19.25 fps (elapsed: 03:29:54)
[15:39:36] *** Encoding : Pass two
More data:
[16:01:02] User requested stop!
[16:01:02] Detected audio: ID#2:A_AAC (44100Hz 16bit 2ch 128kbps) Language: und
[16:01:02] Attempting to convert A_AAC audio track #2...
[16:01:02] Encoding A_AAC to AC3...
[16:01:02] Trying to encode audio with ffmpeg...
[16:01:02] All attempts failed!
[16:01:02] Audio codec (A_AAC) is unsupported! Skipping track.
[16:01:02] Video codec -1 is not allowed in AVCHD/BDMV...
[16:01:02] Video height (-1) not compliant (480/576/720/1080)! Final output may be distorted.
[16:01:02] Not enough data for meta creation!
[16:01:02] Skipped!
[16:01:02] No compatible folders/files processed...
do u teevee?
ummm dont wanna sound like a jerk but a 720p video wont play in a standard dvd player no matter what you use since the resolution is 720x480 or 704x480 for standard dvd. why use a program thats made for HD video to be kept as HD video for this??? just use convertx2dvd.
MultiAVCHD will transcode the video to a standard playable format. It lets you choose an option for playing the DVD on regular players.
do u teevee? -
yes i understand that. i've used it for years. trust me convertx2dvd is much more simple and its faster.
more MultiAVCHD/tsmuxer problems
By tailz in forum Authoring (Blu-ray)Replies: 8Last Post: 10th Feb 2012, 12:24 -
multiAVCHD error
By cavusozkan in forum Authoring (Blu-ray)Replies: 7Last Post: 27th Nov 2011, 03:36 -
MultiAVCHD problems; chapter selection crashes program; changing title
By Yanta in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2011, 16:48 -
Is multiavchd a problem?
By volam1 in forum Authoring (Blu-ray)Replies: 1Last Post: 4th Oct 2009, 15:19 -
Problems with MultiAVCHD 3 mkv movies to DB
By Dragonsf in forum Authoring (Blu-ray)Replies: 6Last Post: 27th Jun 2009, 23:41
