Originally I was simply going to add subtitles to HD MP4 formatted videos to play on my Xbox 360. I spent like an hour trying to get one method down, and I failed (lol). So I should move onto using MeGUI, but I've spent to much time working on mere hard subbing, and I figure simply downgrading the resolution of an MKV would be a lot easier and faster.
I'm using a Windows XP desktop and Xvid4PSP. Whenever I try to "convert" MKV videos from something like 720p to 480p, it takes me way to long (nearly 2 hours), for a "fast" conversion at that. I lose quality and it sometimes acts up on frames. I always figured it was my really crappy and old computer, but I just wanted to make sure. On average, people normally tell me their conversions only take a matter of minutes.
~*My Real Question*~
So how can I figure out the video and audio encoding of the video I'm trying to convert. I hope that way, it won't take me hours to "convert" what I shouldn't be converting. I'll just use the same settings it originally had. Would that take time off my "conversion" of going 720p resolution 480p?
Try convert to avi xvid with a low resolution(480p) instead. You wont get faster conversion if you use same settings as the original(HD 720).
Or buy a better media player. Most supports mp4 with external subtitles, http://www.iboum.com/net-media-players.php . -
It's unfortunate, but I was really looking for a faster conversion. To bad lowering the resolution isn't the fastest method here. I didn't know switching over to a 480p avi would be quicker. If I can't get that much of a faster conversion, I might as well stick to MP4 conversions. Still, in the end I'm stuck with getting my stupid hard subbing down. By the way, I was originally using MP4 hard subtitles for my Xbox. I can't really do much to help that. In the end, I'm going to have to work back around getting my hard subs to start working properly. I appreciate the reply, help, and suggestions.
Sooner or later, I'm going to buy a TV Media Player to help ease my entire case. ^^
Change video resolution
By Browneyd in forum EditingReplies: 5Last Post: 11th Jan 2011, 11:34 -
Change resolution from 235:1 to 16:9
By ThaiJan in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 15:16 -
How to change RMVB video resolution?
By williegreg in forum Video ConversionReplies: 2Last Post: 30th Dec 2009, 15:27 -
How do I change video Resolution
By mmkk in forum Video ConversionReplies: 7Last Post: 31st Aug 2009, 18:33 -
How to change video resolution exactly in Virtual Dub Mod 16:9 to 4:3
By afcoff in forum Video ConversionReplies: 1Last Post: 12th Jan 2009, 12:49
