Hello folks,
As you can read above, my tv with USB can't run .MKV movies with audio files .DTS and AC3. The movie runs without audio so I was trying to put a .AAC file into .MKV movie with MKVMERGE but even though it's works fine on PC my TV still doesn't running the file...What's the correct procedure to put an .AAC file into a .MKV movie?
To get the .AAC file from .MKV movie I just converted the MKV movie into .AAC file...
THX!
Try PopCorn MKV AudioConverter. I think it can convert the audio to aac also.
You should try to convert mkv to mp4..mp4 is easily supported by almost every TV...
MKV - DTS to AC3 nightmare
By aaron1104 in forum AudioReplies: 29Last Post: 1st Mar 2015, 12:46 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 11:50 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 15:45 -
By aaron1104 in forum Video ConversionReplies: 1Last Post: 11th Oct 2009, 04:17
