I have a home theater HT-D4500SAMSUNG that is connected to a projector and wanted to see HD movies through the pen as it has a USB port, I tried embedding the legend through the mkvtoolnix program worked correctly and the PC in the projector but the subtitles do not appear. I have also tried for the caption. Srt with the same file name. Mkv movie in a folder but the subtitle does not appear in it. I will have no choice to view the legend?
Please don't cross post in several forums! I removed your other thread.
Be sure click on the subtitle button on your remote.
Does avi files with srt subtitles work? -
Does your TV support subtitle streams muxed into a video (AVI, MKV, etc.)? Or does it require the subtitles to be stored separately (example: movie.avi, movie.srt)? Does the TV support .ass or .sub/.idx format subtitles?
It's probably a good idea to check the manual for the TV and verify what subtitle features it does or doesn't support.If cameras add ten pounds, why would people want to eat them? -
Oops, sorry about that. I just tend to see (and field) the same question in regard to TVs, so often, that I automatically typed 'TV.'
So, the subtitles are in .srt format? Some devices can be rather picky about the format and encoding of .srt subtitles. My older player would only accept them if they were in English (Roman letters only, no double-byte extended ASCII language text), and saved as an ANSI-encoded document (not Unicode).If cameras add ten pounds, why would people want to eat them? -
I've run the test again a movie through a folder with an avi file and another srt subtitles and got so far appear to lack function mkv files to see movies with optimum quality because it is a projector
Home Cinema System advice
By Squid_uk in forum Off topicReplies: 8Last Post: 30th Jun 2010, 16:16 -
home cinema
By aanfield in forum Off topicReplies: 4Last Post: 2nd Jan 2009, 12:25 -
MPC Home Cinema and FLV
By majax79 in forum Software PlayingReplies: 0Last Post: 8th Jul 2008, 18:29 -
Getting sound from Home Cinema to your Tv
By matw79 in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Jun 2007, 07:35 -
sony dvd home cinema
By matw79 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th May 2007, 15:16
