I'll use "BadFrames" in this clip to fix the vertical shake that happens for a single frame here and there. This way I can select only the frames which need to be corrected. Now I face another problem...I can't seem to sync the audio to my video properly. If I get the first half of the video in sync then the second half is out of sync and visa versa![]()
Please help
Video:http://www.mediafire.com/?n8o7d1s60t37r61
Audio: http://www.mediafire.com/?z2qiaziohmxyb5v
Results 1 to 27 of 27
badframes won't change the framecount so sync will be unaffected
was it in sync to begin with ?
was there a delay value when you demuxed it ? if so, you need to use that value when remuxing -
It's a lip synced performance...and the audio on the VHS tape is crap so I wanted to sync it with the CD audio....which is the WAV I provided.
I haven't looked at it yet, but syncing from different sources can be extremely difficult and time consuming. Sometimes , if the versions don't match exactly, it's even more difficult
Audio drift means you usually have to open it up in a NLE (with a timeline and audio waveforms visible) and manually sync up sections. It might take a few hours just to fix a one minute section. Sometimes it never syncs up properly -
I'm thinking the original audio in the VHS must have either been sped up slightly OR there is a 1 or 2 second edit at some point...
I've determined DelayAudio(-0.5) works to keep the beginning in sync and DelayAudio(-1.0) works to keep the end in sync. Now I just have to figure out what to do with the two? lol
This is roughly close, but you'll have to fiddle with the timestretch and delayaudio values to get it closer.
Also it looks like the last chorus , Cher doesn't do a good job of lip syncing (after about 2:18) - it will be almost imposible to fix with linear tools without a glitch - because you have to shrink just that section - it's hard to do with avisynth . If you have a NLE (eg. vegas) you can use something like a velocity curve
Or you can do a creative edit to the video, eg. insert some graphics, animation, that sort of thing over that last section
Code:vid=MPEG2Source("gypsies.d2v") aud=wavsource("gypsies.wav").timestretch(rate=100.2) audiodub(vid,aud) delayaudio(-0.58)Last edited by poisondeathray; 16th Jan 2012 at 12:58.
That is definitely much better...let me try and capture the VHS audio as it may serve as some sort of guide to perfect the ending. I don't think her lip syncing is off so much as the audio may actually be sped up toward the end or there may be a brief edit. Thank you for your assistance as always poisondeathray!!! And I've got MPEG Video Wizard 5.0 (I don't know if that will work with AVS files or not) but I have no idea how to achieve what you mentioned. Let me see what a search turns up...
I managed to make an edit in the audio using Izotope RX and here's the resulting audio:
http://www.mediafire.com/?494kwiw37aa72hh
Script:
vid=AviSource("gypsies.avi").AssumeTFF.Trim(4284,8 959)
aud=wavsource("gypsies2j.wav").timestretch(rate=10 0.2)
audiodub(vid,aud)
delayaudio(-0.58)
#BadFrames(0, blend=true)
ConvertToRGB32(matrix="Rec601",interlaced=true)
I think that is about as in-sync as I'm going to be able to get it but I'm open to suggestions
I knew there was a brief edit there somewhere causing the last part of audio to be out of sync...
There's a few second right before I made the edit that are still out of sync...so perhaps the edit happens earlier on. Not sureLast edited by Cherbette; 16th Jan 2012 at 14:14.
I don't have "gypsies.avi" , so I cannot test the audio in that script
The other option is to fix the video, so it syncs to the audio . Usually this is what people do, or some combination, because even a small change in audio over short period of time is more easily discernable to average viewer/listener -
"gypsies.avi" should be the same as "gypsies.d2v"...I just compressed it to post here for the sake of file size and already trimmed...so the "Trime" line can be "#".
The other option you mention is worth a shot. What function would I use to do such?Last edited by Cherbette; 16th Jan 2012 at 15:29.
It's harder to do in avisynth, because you need curves and non linear functions
But in NLE's , AE, those sorts of programs, you just draw a curve where you want it to speed up or slow down in that section . If you don't do it with a gradual curve (either ramping audio or video), there will be noticable glitch where you did the ramp - because the speed changes too suddenly -
If you wanted to input avs directly you can use premiere avs import plugin
cs4 and below
http://videoeditorskit.sourceforge.net/
cs5+
http://pwolfamv.com/programs/csavs64/
Or you can load the video in directly (save out wav from the script using soundout() or vdub) -
I don't know what that the ".exe" on this page http://sourceforge.net/projects/videoeditorskit/files/PremiereAVSPlugin/1.95/ did but now I'm unable to open AVS with VirtualDub or Premiere lol
Not sure, but that version is very stable. I think all it does is place a plugin in one of the adobe folders, plus add some registry changes so it can be installed/uninstalled
I used it for a few years back in CS4 , and I know quite a few people used successfully it in CS3 + CS4 for that time as well without any problems
Maybe try uninstalling / reinstalling ? -
Uninstall and reinstalled PremiereAVSPlugin-v1.95.exe and still having an issue. Even uninstalled and reinstalled virtualdub and avisynth and did a registry clean with ccleaner...still no luck
strange because avspmod still works. I don't understand...virtualdub opens for just a half of a second then crashes when I try to open avs with vdub. I'm wondering if it has something to do with huffyuv or this line from its website:
"For the technically minded: dependence on virtualdub is now gone and all resizing/conversions are done using Avisynth internals"Last edited by Cherbette; 16th Jan 2012 at 17:31.
Sorry not sure what's going on. Sourceforge is a reliable source. Unless someone hacked them or something like that
I have that same version installed on one of my computers without issues, and I know a few other folks here and on Doom9 do as well
To my knowledge it shouldn't affect any other programs, except Adobe ones
Did you try leaving it uninstalled ? Do you have a restore point ? -
It is currently left uninstalled.
Unfortunately I don't have a restore point on this bare-bones version of XP I'm using
There's also a chroma shift in my video (http://www.mediafire.com/?n8o7d1s60t37r61) (of which I'm using the uncompressed AVI and have just posted the MPG here for size's sake) which I've attempted to correct with ChromaShift(c=12, v=-8) which looks fairly accurate to me but I'm still learning and any feedback would be much appreciated
Best advice for ccleaner (and similar registry "cleaners"): NEVER use it! You might also check this:
http://www.piriform.com/docs/ccleaner/troubleshooting/problems-after-you%27ve-run-ccleaner
TMPGenc can be uninstalled/reinstalled to restore its registry entries.
If you uninstalled the Adobe plugin, the uninstaller would have changed your registry in several ways. I don't know why reinstalling avisynth, etc., shouldn't work. In fact I don't see how the plugin would affect those other apps, it's not known to do so AFAIK - unless its installer changed some file associations. I looked up the installer pages on the 'net, I don't see any instructions at all. All I found was this: http://www.animemusicvideos.org/guides/avtech/videogetbmeth2.htmlLast edited by sanlyn; 21st Mar 2014 at 08:13.
oh lol...I guess I never have heard that expression. I thought perhaps you might have been referring to my clip
Chroma shift after field-matching
By drawar in forum EditingReplies: 4Last Post: 25th Apr 2012, 04:07 -
Time shift from camcorder in PC
By petran63 in forum Newbie / General discussionsReplies: 0Last Post: 2nd Feb 2012, 15:32 -
ADVC-55 and color shift?
By pgoelz in forum Capturing and VCRReplies: 28Last Post: 16th Mar 2010, 17:10 -
Shift the subtitle
By cheerful in forum Newbie / General discussionsReplies: 4Last Post: 9th Nov 2007, 16:13 -
Hardware to correct Chroma Shift?
By durieux in forum RestorationReplies: 1Last Post: 10th May 2007, 03:26
Please help
