Hey guys, my name is Brian. My question is this: I downloaded AVI2DVD (worked perfect), then I downloaded IMGBrun off this site, after AVI2DVD finished her job, I moved onto IMGBurn. IMGBurn let me add the Audio & Video folders/files, read the files, when it got to information/calculation it said 91% for like 4 hours. It never burned the disc. This morning when I woke up, computer was still sayign busy but it was still at 91%. I just closed it. Do you guys know of a freeze issue fix or know any good FREEWARE software to get to burn dvds?
Results 1 to 14 of 14
It's not a progress bar. It's 91% of the dvd media size. You can start burn directly.
But you are not alone, https://forum.videohelp.com/threads/339794-Imgburn-auto-correct-file-system-doesnt-ever-complete , https://forum.videohelp.com/threads/341765-Burning-blue-ray-video?highlight=imgburn
I was waiting on the cd to light up so I could click on it.....??? Thanks man.
I feel like such an a$$ man hahahaa .... ok, so I click on the green disc to start the burn?
You mean to tell me I sat there for several hours when all I had to do was click on burn button? I thought from the pics I saw posted that the disc on the left under the selected drive was supposed to light up. In the forums, under how to use imgburn, it said it would automatically burn ..... smh I'm going to go home later and try it. Thanks
As you learned, ImgBurn does NOT automatically burn. You have to click on the button to start the process. When you start ImgBurn and place a blank disc in your drive be sure that the tabs on the right are on Device. When it fills up with data about your disc you are ready to start burning.
What do you mean, the tabs on the right are on the device? Also, which button is it that starts the burn? I'm just trying to get this right.
You've exceed my patience. Rather than insult you I'll just politely say that I'm done here.
Nevermind man, I gpt it. You're saying make sure it is on device? Ok. It was on device and it read 91%. I just don't know what button to push to start the burn process but I'll figure it out.
Follow a guide! http://adubvideo.net/how-to/burn-single-layer-video-dvds-imgburn
That's what I was saying, the folder with the disc wasn't lit up?? I had my burner selected, blank disc but the option to burn wasn't lit up
Test again with some other files.
And does it say something at the bottom bar? For me it says Disc Not Empty when I haven't inserted a dvd media.
And I guess you have been able to burn something with other software using your dvd writer? -
Yep! It will do all this and then it says duration 00:00:00 but then nothing else
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
Registration won't finish (vob2mpg pro)
By kfealz in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2010, 08:13 -
NOT finish DVD
By black lion in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2009, 19:40 -
DVD burner won't finish burn
By JDShaffer in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Jul 2007, 21:41 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
