I need to extract audio from .vob and save it MP3 format.
Is this feasible?
If yes, then which utilities/tools should I use for the same.
Will the quality of audio when extracted from vob files get degraded ?
Thanks in advance
You can try Pazera Free Audio Extractor or AoA Audio Extractor Basic. Both are free. Or DVD Audio Extractor if you want more features.
If you reconvert to mp3 you will lose quality depending on the audio bitrate you choose. -
FormatFactory (freeware) also does a good job.
Read the warnings about codec installation or use a portable build. -
The audio in VOB files is most likely AC3. You can demux that, as above, with e.g., PGCdemux, and get exactly the same audio as an AC3 file.
This may be 1, 2, 5 or 6 channels.
Most media players can play AC3 as-is, so you may not need to convert it at all.
If you do want to convert to MP3, that is stereo only, so you may need to downmix it.
There are many audio converters, e.g. Foobar2000.
Extract Audio from DVD Files
By foochuck in forum DVD RippingReplies: 7Last Post: 19th Jan 2010, 06:11 -
How to Extract Audio From WMV Files?
By devilcoelhodog in forum AudioReplies: 10Last Post: 23rd Jun 2009, 11:32 -
Extract subtitles from VOB files
By webstar in forum MacReplies: 9Last Post: 29th May 2009, 16:34 -
Batch extract audio from multiple DV files?
By Colmino in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st May 2008, 11:55 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 05:56
