  1. IF anyone has any information on how to extract video from a VCD, I would really appreciate some help!!!
    Thanks a million, if I missed a FAQ on this, I appologize.
    Dan
    niuphan@yahoo.com
  2. You can use a program called vcdgear to extract the dat file and convert it to mpeg. There are guides on the this site if you need them.
  3. As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. thanks guys, I figured it out!!!
    I guess I confused DAT with digital audio tape
    peace
    dan
  5. I know this might have been answered for you already, but there is also another way to extract the MPG from the VCD. Just use isobuster to extract the MPG . It works great and is fairly fast.
  6. The DAT file is not quite the same as MPEG and it is a good idea to convert it back.
    VCDGear is probably the best program to do this and can do it directly from the VCD. It takes no longer than copying the file and does not affect the quality.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  7. You guys know what program is good for converting a non-VCD compatible mpeg into a compatible one?
    thanks guys!
    dan
