Results 1 to 12 of 12
Do you have the DivX or Xvid codecs installed on that computer?
Could be that it doesn't come with its own installation of them, so without a separate install, it wouldn't know how to handle them.
Scott -
Neither are directly supported. First check which codecs are supported (audio and video). If yours is then just demux/remux to a supported container like avi/mpg/mp4/mxf. In general they only support transport streams in the context of a supported camcorder format (e.g. TS for HDV or MTS for AVCHD).
It seems the policy is wide acceptance of production formats even AC3 but inconvenience for downloadable media or commercial DVD/Blu-Ray.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I installed the divx codecs but it still doesn't work. I'm not sure if they are 64-bit or not.
Sounds like a pain to always convert videos before importing into vegas. Maybe it's better to get a different program than Vegas? Are there any which support mkv/avi-divx and are as good as Vegas? -
pretty much all high end video editors are geared toward production formats as source material, not end user ones that are already highly compressed.
In that case, what's the best codec and container to convert the source files to? Assuming you want good quality but not overly large output files.
I think Vegas uses VFW codecs to access AVI files. Divx doesn't install a 64 bit VFW decoder. Try installing a 64 bit Xvid codec.
Thanks! I installed the xvid codec and now I can open the videos.
I have win 7 , 64 bit, ffdshow 32 bit, Vegas 8c and DivX, Xvid and others like HuffYUV would load into Vegas.
You need to allow it in VFW configuration for ffdshow. Click decoders and change disabled for XviD ,DivX and whatever you need change to libavcodec.
Then after loading those clips, DivX, HuffYUV into Vegas it would show in properties codec as ffdshow.
oh, I see, this is 32 bit vs. 64 bit codecLast edited by _Al_; 17th Jan 2012 at 10:09.
Sometimes you can re-wrap mkv into .m2ts or mp4 and it will work for import; but some encoding settings can make it imcompatible for vegas to decode
But if you know how to use avisynth, almost any file can be loaded into vegas with avisynth virtual file system (AVFS), including mkv, by frameserving (no large intermediate files)
Best MKV to Avi=divx/xvid
By s-toon in forum Video ConversionReplies: 9Last Post: 9th Aug 2011, 15:50 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
importing x264 mkv files into Sony Vegas 9
By pred in forum EditingReplies: 0Last Post: 26th Jul 2010, 13:12 -
Importing xvid and divx into vegas - a solution ?
By BJ_M in forum Video ConversionReplies: 55Last Post: 13th Apr 2010, 15:16 -
Playing HD (.mkv) and XViD\DiVX (.avi, .wmv)
By yonyz in forum Software PlayingReplies: 10Last Post: 25th Feb 2009, 13:18
