hey there. I've got a snag, but I'm not sure if it's my fault or if it's normal behavior.
I can rip with SmartRipper and with CladMdec. I get big healthy *.vob files, i think. i can even re-name them to mpeg and get them to play, but i get no sound. I also can't preview with sound in DVD2AVI, and it won't let me select the "process WAV" menu option. However, when I save the AVI, it does indeed output a sound file. Is there a problem with the way I'm handling the files, or is this how it's supposed to work?
Yup, you shouldn't be renaming the VOB files for starters, what i suggest you do is follow the Classical Newbie Guide, and make sure you follow the steps: http://www.vcdhelp.com/dvdtovcd.htm
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Ripping, converting audio and then authoring the DVD
By vishwanath in forum Authoring (DVD)Replies: 10Last Post: 13th Jun 2011, 23:58 -
ripping and converting
By bigmacsexgod in forum DVD RippingReplies: 1Last Post: 26th Dec 2009, 12:40 -
Ripping And Converting
By Lennoxtown in forum Video ConversionReplies: 4Last Post: 17th May 2008, 05:39 -
No sound after converting/ripping
By breezestar in forum Newbie / General discussionsReplies: 8Last Post: 30th Jan 2008, 11:08 -
help with ripping the individual episodes from the dvd and converting them
By dvdrburner in forum DVD RippingReplies: 1Last Post: 22nd Aug 2007, 08:14
