I was just doing some encoding tests and noticed after I encoded MPEG2 from Sony Vegas and played the file back via VLC and Windows Media Player, the encoded file looks significantly darker than when I view the same encoded video on the Vegas timeline. Is this normal? I will actually be using Adobe Encore CS3's encoder when the time comes. Is it wise to make the video a little lighter if encoding makes it darker?
You need to adjust both to a color bar or ramp. But a properly adjusted video level will always appear slightly dark on the desktop. It is a mistake to adjust video levels to look good on a computer display although you can get the overlay close. Computers and TV displays use different gamma.
http://www.kiva.org/about
!!!3D playback with VLC, MPC, WMP, HELP!!!!!
By NateDizzle in forum Software PlayingReplies: 6Last Post: 17th Feb 2012, 20:31 -
VLC looks washed out compared to WMP
By stringcheesy in forum Software PlayingReplies: 3Last Post: 12th Sep 2011, 00:27 -
major difference in playback quality between vlc and wmp
By octeuron in forum Newbie / General discussionsReplies: 6Last Post: 26th Feb 2010, 18:05 -
VLC to release NLE in February 2010
By MJ Peg in forum Latest Video NewsReplies: 19Last Post: 24th Feb 2010, 11:16 -
HD Mpeg2 Stream - playback/edit issues. Even VLC chokes
By bengance in forum DVB / IPTVReplies: 29Last Post: 2nd Nov 2007, 12:05
