Its been a long time since I paid attention to this kind of thing, I vague remember some cautions, but not what...
I have a Sony gizmo called an IC Recorder that is basically a tiny stereo AGC voice recorder for mp3. It has an alternate mic input using a miniplug.
My question is whether it is safe to connect that input to the headphone output of the laptop; not just for a quick try but over longer time periods. I don't want to blow the input.
Anybody know for sure? Thanks!
Do you have any specs for the Sony; do they mention what's the max input level? Typical audio equipment has 1 Vpp on the line-in. It should be ok if you start low; open windows sound mixer and set the volume level to the lowest and record something short that plays loud, then open the MP3 in audacity and check that the top of the wave form is not a flat line (clipping). Increase the volume a bit and record the same thing again, repeat until the wave form starts to clip. That volume level is 100%, set the volume to 75% and you'll be alright.
Mic level inputs are very low relative to headphone out. It may blow the device but most will accept a wide range of input levels up to line level (headphones are way above that). Not so sure about Sony which likes you to use their mics and also likes to charge high for service.
If you want to risk it, set output levels to minimum and increase slowly. Back off at any sign of distortion, rude noises, smoke or fire.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
@transporterfan- it is a more advanced device, the ICD-UX71; manual is here http://www.docs.sony.com/release/ICDUX71_81_EN.pdf
but it doesn't detail anything other than there is both AUDIO IN and MIC In
What I wanted to record is a streaming mp3 that is supposed to be available as a downloadable podcast from itunes (but isn't). My concern was artifacting when recording an mp3 output as an mp3
@nic- that was the method I was thinking of, but this recorder is sooo handy*, I got nervous about frying its input- the usually good Sony instructions are minimal- no levels given
@edDV- the headphone out on the laptop can barely drive a set of Sony unpowered Walkman speakers, but again no specs given.
*this is the unit that works with Dragon Voice recognition.Last edited by ahhaa; 15th Jan 2012 at 23:10.
Forget that, I just looked at the manual, there's no Audio_in connector on the recorder and the specs on the mic in are too low. If quality isn't that important, why don't you just put the recorder between the speakers or even headphones and record the podcast that way.
HD TV to Laptop Problem (connecting audio and video simultaneously)
By hamid22689 in forum DVB / IPTVReplies: 7Last Post: 14th Mar 2012, 11:35 -
Splitter for Digital Audio cable? 1 Amp but 2 devices
By thegeeman in forum AudioReplies: 2Last Post: 8th Feb 2010, 14:29 -
connecting laptop to the tv
By ieh4f in forum ComputerReplies: 5Last Post: 11th Oct 2008, 03:59 -
Connecting Laptop to TV
By siddss16 in forum Newbie / General discussionsReplies: 9Last Post: 12th Sep 2008, 15:10 -
Connecting MP3 Players to playable devices
By ElBoricua433 in forum AudioReplies: 11Last Post: 31st Aug 2007, 23:16
