Hi,
I am editing a project in Premiere Pro with .mov files straight from a Canon 5D. Some footage in my sequence I have sped up by 5000%, both the video and the audio. When I play this in Premiere, all is fine, but when I export (with all of the export settings matching that of the sequence settings) the final .mov file has no audio from the sped up footage. There is other audio on the same track which is there on the exported clip, and I have also tried putting it on a seperate track.
Any ideas would be much appriciated!
Thanks.
Can you export audio track separately & successfully? e.g. aiff or pcm wav ?
It does the same thing. Exports all the other audio except the speeded up clips.
I don't know the cause of this problem, but here's how I worked around it.
Right click the clips you wish to time remap and send them to an After Effects composition and do time remapping there. Drag and drop the AE comp onto the timeline, sometimes, or always it will just replace the audio automatically.
dv exported from premiere isn't microsoft dv, it is sony dv; why?
By codemaster in forum EditingReplies: 2Last Post: 31st Dec 2011, 09:28 -
Premiere Pro on OSX - mpeg2 clip audio missing
By Mylo in forum EditingReplies: 2Last Post: 17th Feb 2011, 07:00 -
strange sounds in audio exported from premiere pro cs3
By codemaster in forum EditingReplies: 0Last Post: 25th Jan 2011, 19:57 -
Exported AVI from Premiere pro2 have problem!!!
By yunakokimama in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2008, 21:29 -
DVD exported from Adobe Premiere Elements Help
By Captain Satellite in forum Newbie / General discussionsReplies: 2Last Post: 27th Dec 2007, 19:09
