I have an older DVD-recorder Samsung dvd-r 121 and it says disc error on all new dvd-rw I through on it. I guess the recorder need a new firm-ware, but canīt find any. Do any of you know if there is any firmware available or is it no option but throw it a way?
Firmware doesn't fix broken stuff.
Good quality DVD-R media is cheap these says. I'd just use those and stop using RW discs. The first thing to "go" on my old Philips recorder was the ability to use RW discs. -
But it plays old RW discs that have been initialized earlier. Itīs all these new disc I try that give the error after the initializing process. I thought it might be because they are newer and the firmware needed an update, but I donīt know....
Samsung DVD/VHS Recorder
By fayt in forum DVD & Blu-ray RecordersReplies: 3Last Post: 26th Apr 2009, 00:28 -
Any experience with Samsung HR 773 DVD recorder?
By szalaikornel in forum DVD & Blu-ray RecordersReplies: 0Last Post: 14th Jan 2009, 07:09 -
Using Samsung DVD-recorder through hi-fi problem
By kwil in forum Newbie / General discussionsReplies: 0Last Post: 26th Nov 2008, 13:24 -
Samsung DVDHR730 DVD Recorder with 80GB
By ricksta77 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Aug 2008, 09:43 -
Samsung DVD recorder
By aye in forum DVD & Blu-ray RecordersReplies: 2Last Post: 22nd May 2007, 08:01
