I'm interested in using the Intensity Pro (http://www.blackmagic-design.com/products/intensity/ ) to record my Xbox 360 gameplay.
I'll be installing it to my computer (http://support.gateway.com/s/PC/DX/1015700R/1015700Rnv.shtml ).
Are the computer specs even good enough to record video, preferably up to HD?
My desktop (VGA) and Xbox 360 (HDMI) are connected to the same computer monitor with a native resolution of 1680x1050.
I have my Xbox set to a resolution of 1680x1050 (looks the best) but I can change it to 720p or 1080p.
According to the Intensity Pro specs, it doesn't support 1680x1050 recording, so I would have to change my Xbox to 1080/720p right?
Thanks.
not likely to work - your comp and video probably isn't good enough.
http://www.blackmagic-design.com/support/detail/supportnotes/supportnote/?sid=3947&pid...DK=0&snid=9568
and especially check video card requirements link and hard drive requirements for HD.--
You might want to look into getting a hauppauge hdpvr instead if your computer can't handle the blackmagic as aedipuss is hinting at.
The hdpvr records component up to 1080i (your xbox must be set to 480, 720 or 1080i prior to connecting for it to register). You can do 5.1 dolby digital via fiber optic. The hd pvr records h264 into either a mp4, m2ts or ts file. - edit - also the hdpvr has component pass through so you can play it on the tv while recording.
You can easily get the component cable for the xbox 360.
Also the hdpvr works well on a dual core pc. My hdpvr runs fine on a dual core 2.7ghz amd processor - 2gbs ram with vista premium 32bit
Edit - the hdpvr is an external box that connects to your computer via usb.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Black Magic Intensity Shuttle or Intensity Pro?
By perasbro in forum Capturing and VCRReplies: 3Last Post: 12th Oct 2011, 18:56 -
Black Magic Intensity Pro [Question]
By Dionesos in forum Capturing and VCRReplies: 5Last Post: 7th Jul 2010, 08:40 -
By andy6590 in forum Capturing and VCRReplies: 0Last Post: 24th May 2010, 14:19 -
By birck66 in forum Capturing and VCRReplies: 0Last Post: 14th Apr 2010, 19:38 -
Black Magic Intensity Pro Requirements
By kILLDR3n in forum Capturing and VCRReplies: 13Last Post: 9th Dec 2009, 02:08
