Who is the best way to upscaling a video witch I take from a PAL DVD (vob 720x576) to 720p.
If this help I use SONY VEGAS PRO version 11.
Thanks a lot !!
				Results 1 to 11 of 11
	Best way is to let your player do it.
 You could try the following:
 http://www.infognition.com/videoenhancer/
 There is a forum link here which may help you. You would have to use VirtualDub and Avisynth:
 http://www.dvinfo.net/forum/non-linear-editing-pc/140965-how-upscale-sd-hd.html
 There is a lot of work involved and you will probably not improve much over a players built-in upscaler IMHO.
	@epsilonalpha,
 The OP said nothing specifically about ENCODING, so to presume that is a bit premature.
 One can do it in software to encode to a newly stored file, one can do it in software during realtime playback, or one can do it in hard/firm-ware during playback either within the video card or within the TV.
 The "best quality" would probably be the 1st, using Vdub & AVISynth as transporterfan suggests (or using $$$ pro software), but he's right in that the hard/firm-ware options in most video card or TVs have improved to the point where it makes no sense to waste time doing it any other way (unless one was incorporating it in a newly edited/composited piece).
 http://www.kiva.org/about
	Animated material upscales better than real world video. See this post for an example:
 https://forum.videohelp.com/threads/329129-DVD-to-HD-%28resize-and-enhance-image-quality%29
  capturing PAL signal as 1080i, 720p or just PAL ?By adom in forum Capturing and VCRReplies: 3Last Post: 30th Aug 2011, 06:10
  HDTV 720p 50 fps -> SDTV PAL 576i/p 25fpsBy joosty in forum Video ConversionReplies: 22Last Post: 7th Nov 2010, 23:33
  To convert from HDV-Apple Intermediate Codec 720p to PAL-please help.By AnnaC in forum Newbie / General discussionsReplies: 3Last Post: 31st Oct 2010, 09:29
  UNDERWATER VIDEO - Should I get a still-cam with 720p, or a 720p camcorder?By v1ru5 in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2009, 03:49
  AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 20:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
