I want reduce the file size of my porn collection by 25 to 50%. I am okay with video quality comparable to youtube. I don't care much for the audio quality as long as I can hear it. Please help me with the following:
1) Should I keep the original video format or change it to x264?
2) Should I keep the original bitrate or change it? To what?
3) Should I keep the original resolution or change it? To what?
4) How do I change the audio bitrate and sample rate so I can hear it, but reduce quality?
Filesize = bitrate * running time
So if you wanted 50% size, reduce the combined bitrate of audio & video by 50%
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 23:10 -
size of my VOB reduced after re encoding
By mathmax in forum Authoring (DVD)Replies: 11Last Post: 14th Dec 2011, 22:27 -
settings to encode video for sanyo incognito
By tater1969 in forum Portable VideoReplies: 0Last Post: 26th Apr 2010, 09:10 -
Xvid Encode by File Size Problem
By hech54 in forum Video ConversionReplies: 5Last Post: 1st Jul 2008, 12:45 -
Audiobook - improving a 8 kbps (reduced quality) file
By Cooly-O in forum AudioReplies: 6Last Post: 7th May 2008, 01:06
