  1. hi there, i'm having a problem with multiavchd
    i'm adding subtitles (srt) to an imported blu-ray ive ripped (yes i own it)
    ive closely following the steps laid out HERE,
    but when multiavchd gets up to remuxing the stream with the movie in it, there is an error
     [14:02:30] *** Detected sub-path #: [ID#000, IN: 00:10:00.000] [IGS]
    [14:02:30] *** Playlist duration  : 00:00:00.000 (5 MiB)
    [14:02:30] Added Blu-ray disc in re-author mode.
    [14:02:30] In re-author mode multiAVCHD funcionality is restricted.
    [14:05:22] Checking for available space and drive types (FAT32/NTFS)...
    [14:05:22] Check failed!
    [14:05:22] Log started for multiAVCHD v4.1 (build 770)
    [14:05:22] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
    [14:05:22] Existing C:\multiAVCHD\BDRA\ cannot be used as destination folder!
    [14:05:22] Output will be written to: C:\multiAVCHD\BDRA-20120113-140522
    [14:05:23] Entering Blu-ray re-author mode...
    [14:05:23] *** Transferring structure...
    [14:05:23] *** Processing media files...
    [14:05:24] *** [00001.mpls] - Remuxing playlist...
    [14:05:25] SmartLabs tsMuxeR.  Version 1.10.6  http://www.smlabs.net
    [14:05:25] Detected resolution: 1920x1080
    [14:05:25] Detected video: V_MPEG4/ISO/AVC (TID#4113)
    [14:05:25] Only this video track will be used!
    [14:05:25] Detected media file: 00002.m2ts
    [14:05:25] Detected media file: 00003.m2ts
    [14:05:25] Detected main PI#000: 00002.m2ts, Duration: [01:30:21.416], [PTS: 01:10:00.000 / 02:40:21.415]
    [14:05:25] Detected main PI#001: 00003.m2ts, Duration: [00:00:13.012], [PTS: 02:40:16.000 / 02:40:29.013]
    [14:05:25] Using audio: A_LPCM (ID#4352 / language: jpn / delay: 0)
    [14:05:25] Using subtitles: ID#4608:S_HDMV/PGS Language: jpn
    [14:05:25] Adding subtitles (Gundam Wing Endless Waltz Movie (1998) BLURAY.srt) (eng)
    [14:05:25] Creating clip and playlist info (tsMuxeR)...
    [14:12:45] *** Failed!
    [14:13:04] *** [00000.mpls] - Processing playlist
    [14:13:04] *** [00002.mpls] - Processing playlist
    [14:13:04] *** [00003.mpls] - Processing playlist
    [14:13:04] *** Checking playlists and media dependencies...
    [14:13:05] *** [00002.m2ts] Error!
    [14:13:06] Re-authoring completed...
    [14:13:06] Done!
            Compilation summary:
            Format: Blu-ray player (BD-R/BD-RE disc)
            Output size      : 598 MiB (0.584 GiB)
    the size of the disc is supposed to be about 30gb obviously 600mb is nowhere near that,
    here is what mediainfo has to say about my movie...
     Report for file: 00002.m2ts
    General / Container Stream #1
    	Total Video Streams for this File.................1
    	Total Audio Streams for this File.................1
    	Total Subtitle Streams for this File..............1
    	Video Codecs Used.................................AVC
    	Audio Codecs Used.................................PCM
    	SubTitle Codecs Used..............................PGS
    	File Format.......................................BDAV
    	Play Time.........................................1h 30mn
    	Total File Size...................................27.3 GiB
    	Total Stream BitRate..............................43.2 Mbps
    Video Stream #1
    	Codec (Human Name)................................AVC
    	Codec (FourCC)....................................27
    	Codec Profile.....................................High@L4.1
    	Frame Width.......................................1 920 pixels
    	Frame Height......................................1 080 pixels
    	Frame Rate........................................23.976 fps
    	Total Frames......................................129984
    	Display Aspect Ratio..............................16:9
    	Scan Type.........................................Progressive
    	Color Space.......................................YUV
    	Codec Settings (Summary)..........................CABAC / 4 Ref Frames
    	QF (like Gordian Knot)............................0.789
    	Codec Settings (CABAC)............................Yes
    	Codec Settings (Reference Frames).................4
    	Video Stream Length...............................1h 30mn 21s 416ms
    	Video Stream BitRate..............................39.2 Mbps
    	Video Stream BitRate Mode.........................VBR
    	Bit Depth.........................................8 bits
    	Video Stream Size.................................24.7 GiB (91%)
    	Color Primaries...................................BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    	Transfer Characteristics..........................BT.709-5, BT.1361
    	Matrix Coefficients...............................BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio Stream #1
    	Codec.............................................PCM
    	Codec (FourCC)....................................128
    	Audio Stream Length...............................1h 30mn 21s 410ms
    	Audio Stream BitRate..............................2 304 Kbps
    	Audio Stream BitRate Mode.........................CBR
    	Number of Audio Channels..........................2
    	Audio Channel's Positions.........................Front: L R
    	Sampling Rate.....................................48.0 KHz
    	Bit Depth.........................................24 bits
    	Audio Stream Delay................................1h 10mn
    	Audio Stream Size.................................1.45 GiB (5%)
    Subtitle Stream #1
    	Format............................................PGS
    	Codec ID..........................................144
    ALSO: I've tried to open this file up in tsmuxer and it won't recognize the stream...
    please! any help or advice would be greatly appreciated, thank you
    canada
    The log states that there's not enough disc space to complete your reauthor.
  3. alright, the destination folder was in a place with plenty of space and so is the temporary files folder
    does the temp folder have to be located on a FAT32 or NTFS formatted drive?
    this is what i'm getting now...
    [16:49:12] Checking for available space and drive types (FAT32/NTFS)...
    [16:49:12] Check failed!
    [16:49:12] Log started for multiAVCHD v4.1 (build 770)
    [16:49:12] Selected output mode: Blu-ray player (BD-R/BD-RE disc)
    [16:49:13] Entering Blu-ray re-author mode...
    [16:49:13] *** Transferring structure...
    [16:49:13] *** Processing media files...
    [16:49:14] *** [00001.mpls] - Remuxing playlist...
    [16:49:15] SmartLabs tsMuxeR.  Version 1.10.6  http://www.smlabs.net
    [16:49:15] Detected resolution: 1920x1080
    [16:49:15] Detected video: V_MPEG4/ISO/AVC (TID#4113)
    [16:49:15] Only this video track will be used!
    [16:49:15] Detected media file: 00002.m2ts
    [16:49:15] Detected media file: 00003.m2ts
    [16:49:15] Detected main PI#000: 00002.m2ts, Duration: [01:30:21.416], [PTS: 01:10:00.000 / 02:40:21.415]
    [16:49:15] Detected main PI#001: 00003.m2ts, Duration: [00:00:13.012], [PTS: 02:40:16.000 / 02:40:29.013]
    [16:49:15] Using audio: A_LPCM (ID#4352 / language: jpn / delay: 0)
    [16:49:15] Using subtitles: ID#4608:S_HDMV/PGS Language: jpn
    [16:49:15] Adding subtitles (Gundam Wing Endless Waltz Movie (1998) BLURAY.srt) (eng)
    [16:49:15] Creating clip and playlist info (tsMuxeR)...
    [16:55:30] *** Completed!
    [16:58:34] *** [00000.mpls] - Processing playlist
    [16:58:34] *** [00002.mpls] - Processing playlist
    [16:58:34] *** [00003.mpls] - Processing playlist
    [16:58:34] *** [00001.mpls] - Applying changes...
    [16:58:34] *** Checking playlists and media dependencies...
    [16:58:35] *** [00002.m2ts] 1920x1080p, 23.976fps [00:00:00.000]
    [16:58:35] *** Caching all playlists...
    [16:58:35] *** Caching completed!
    [16:58:35] *** Applying changes to linked playlists...
    [16:58:35] *** [00001.mpls] - Applying changes...
    [16:58:37] Re-authoring completed...
    [16:58:37] Done!
            Output size      : 6815 MiB (6.655 GiB)
    [16:58:37] C:\multiAVCHD\AVCHD folder created (AVCHD/Blu-ray output)!
    it gets up to about 7 gigs and then gives out for some reason
    and it's still saying i dont have enough free space...
