Newegg has several internal Blu-ray burners for under $90. If I were to buy one of them, what would I need to connect it to my laptop? I have a USB 3.0 port plus a "USB 2.0 with E-SATA & Power Share" port. Do I need to buy an enclosure? Or is a cable like this one sufficient?
Assuming that I don't need an enclosure, is it still better to use one? Would it have to be a special "blu-ray enclosure" or is there no difference between it and a DVD drive enclosure?
I don't really want to spend the extra $40 for an internal drive if I don't have to, but all this other stuff's got me confused. All I really know is that when a drive enclosure has the word "blu-ray" in the title, the price jumps $20.
The short answer - you need an enclosure
The slightly longer answer - or a bespoke external blu-ray drive(not an internal one)
The much longer answer:
1. That cable only transfers data.
2. The internal drive will inevitably require a seperate power connector usually a SATA type and you can not connect that to a laptop AFAIK.
3. The extra cost for blu-ray. Possibly for more, or better fans. -
Staples has a USB 2 Memorex Blu Ray WRITER for $99 online. I got one it's a Pioneer inside. It's about as big as a disk & comes with software. I used a $25 off $100 coupon to get it for $75.
I also have one in an enclosure, enclosure I bought from Amazon for $33.
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 03:35 -
how to connect pc 5.1 speakers to blu ray player
By robinmishra in forum AudioReplies: 6Last Post: 12th Mar 2011, 09:36 -
Best internal blu-ray writer?
By hasselblad in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Jan 2011, 21:01 -
Is it necessary for a laptop having an HDMI port if it has no Blu-ray drive
By coody in forum ComputerReplies: 7Last Post: 29th Nov 2010, 20:35 -
Blu-ray in Apple MacBookPro upgrade? internal slot loading?
By rjamesd05 in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Mar 2008, 03:58
