My main aim is convert teletext in DVB ts to some subtile format.
I have extracted teletext from DVB-T transport stream using ffmpeg like below
ffmpeg.exe -i TELETEXT.mpg -vn -an -f rawvideo -copyinkf -scodec
copy teletext.dat
How can I convert teletext.dat into other subtitle formats like .srt, .sup
etc.
Results 1 to 9 of 9
See above if it can help you with something...
---> http://www.extrabuttons.net/ ( TT subripper)
---> http://forum.doom9.org/showthread.php?t=124487
Thanks. -
This information can help you?
http://www.videoredo.net/msgBoard/showthread.php?t=4784
https://forum.videohelp.com/threads/338209-telxcc-%28TS-teletext-subtitles-SRT-extractor%29
http://ask.metafilter.com/175373/Extracting-subtitles-from-recorded-Australian-TV
http://www.gossamer-threads.com/lists/mythtv/users/431560
http://forums.gbpvr.com/showthread.php?48535-How-to-capture-teletext-subtitle-to-srt-i...r-Unicode-quot
Thanks.Last edited by devilcoelhodog; 14th Jan 2012 at 10:22.
@zorr00000, I put your question below.
Maybe someone can help your problem.
If you find useful, register yourself in that place and clarify your issues. :P
---> http://forum.doom9.org/showthread.php?t=163802
ThanksLast edited by devilcoelhodog; 14th Jan 2012 at 10:21.
If they are the same as EIA-608 you can try eac3to
see here
https://forum.videohelp.com/threads/341312-How-to-extract-Close-Captions-%28EIA-608%29-from-ts
If you don't know what they are, please post a sample -
Thanks for your help. I was able to convert into .srt file using DVBTextSub -srt -out teletxt.srt < teletext.dat
Hi. I'm glad that you can do it.
---> http://sydney.edu.au/engineering/it/~efax/DVBTextSub.htmlThanks for your help. I was able to convert into .srt file using DVBTextSub -srt -out teletxt.srt < teletext.dat
---> http://www.videoredo.net/msgBoard/showthread.php?t=19527
---> http://sydney.edu.au/engineering/it/~efax/DVPiper.html
---> http://www.how-to-uninstall-program.com/uninstaller/uninstall-dvbtextsub-0-5u-dvbtexts...installer.html
---> http://www.softpedia.com/get/Multimedia/Video/Other-VIDEO-Tools/DVBTextSub.shtml
---> http://sourceforge.net/projects/dvbtools/
Thanks.
devil (johner)
Huffyuv+pcmaudio 2 clips = diff data formats?!?!
By duhmez in forum EditingReplies: 2Last Post: 19th Apr 2011, 20:48 -
VirtualDub Error: The audio streams have incompatible data formats
By UMO in forum Newbie / General discussionsReplies: 4Last Post: 9th Apr 2010, 03:38 -
Mux raw subtitle streams in a existing mpeg file.
By etvideob in forum LinuxReplies: 0Last Post: 14th Aug 2009, 03:22 -
WMV files go with which subtitle formats?
By binocular222 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2007, 11:49 -
Subtitle formats and sync
By Raztax in forum SubtitleReplies: 4Last Post: 13th May 2007, 14:49
