Hi,
I have the Motorola DCH3416 with my cable provider. I want to try to get some recordings off there. I used to use a WinTV PVR but it doesn't work with my Win7 64-bit new computer. I've tried using this CapDVHS software with my laptop and Firewire, but that didn't work either. What devices can I use to do this and also capture video from a VCR? Is there a DVD HDD recorder that would do the trick that wouldn't be too expensive? I don't care if I have to record with component video and audio. More important to keep it cheap, after all I'm capturing SD content anyway and the HD content I have on my DVR doesn't need HD quality.
Thanks to anyone who can help!
So there's no way to do this via a DVD HDD recorder? I thought you could simply connect any analog source and record to a blank DVD-R or DVD-RAM?
http://www.kiva.org/about -
I was just thinking the same thing. Maybe with this: http://hauppauge.com/site/products/data_hvr1150.html
Sorry, thought you meant direct digital -> digital, not digital -> analog -> digital. There's so much loss that way, I rarely consider it anymore, even as a last resort (which it still is, but possibly not for long).
Scott -
Unless you go the IEEE-1394 route*, digital -> analog -> digital is the only other option. Two ways.
SD - S-Video or composite + white/red RCA audio to DVD recorder or capture device.
HD - Analog component + Digital audio to a device like the Hauppauge HD-PVR.
* discussed elsewhere.Recommends: Kiva.org - Loans that change lives.
Motorola DCH3416 STB capturing
By NitroVideo in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2014, 15:32 -
Motorola DVR Capture Handholding Help
By alaskajoe in forum Capturing and VCRReplies: 7Last Post: 24th Nov 2011, 20:34 -
Motorola dcx3501 DVR drivers?
By dbanimal in forum Capturing and VCRReplies: 2Last Post: 16th Nov 2011, 13:57 -
Motorola HD DVR what can I do with it?
By DirtBikeMike in forum Newbie / General discussionsReplies: 2Last Post: 24th Sep 2010, 06:39 -
Can you disable onscreen popup messages on motorola dvr DCH3416?
By yoda313 in forum Off topicReplies: 0Last Post: 26th Jun 2009, 20:24
