I have both VLC and mpchc, but I find VLC looks better with lower rate video and I use it more often.
However, I ripped my Lord of the Rings to DVD-9 on my HD with DVDFab HD Decrypter (ie. I assume no encoding) yesterday. It plays a bit choppy in places with VLC but not mpchc. I wasn't expecting this.
I'm using an i3 with 4 Gb and no frakkin' codec packs. My monitor is 60Hz. And I'm just curious if anyone else has had this issue with VLC.
It's 1.1.0, not that old.
I've seen the release of a newer version in the Tools section before but it seems to be beta and I don't generally do beta. -
Thanks, but I'm not really that interested in debugging if I have another program installed that works.
OK, problem solved. poisondeathray, you were right about versions. As I've been told a number of times by knowledgeable buddies, VLC is kind of buggy. They're right.
Uninstalling 1.1.11 and installing 1.1.05 works fine. Plays VOBs without a hitch.
Apparently I shouldn't stream from the web with this version, which I don't do anyway. -
bit of advice needed ,please as i am new to this site and all the jargon that goes with it ,i have a panosonic tm 900 camcorder and video in the top settings 1080p but have a problem as to view it direct from my pc after downloading it is stop start using VLC player ,ok on my laptop using windows 7 and the media player ,but on my two tower,s using windows xp the media player will not play it ,now once i have processed it and compressed it ready to upload to youtube or any of the bowls sites i supply bowling vids to it is very good even from a disk player on the tv its very good quality .but ive no way of playing un processed files . have you any idea,s please.
to view some of the vids go to 1947westy on youtube.
VLC Blu-ray plugin - Watch encrypted Blu-rays directly in VLC 2.0+
By Baldrick in forum Latest Video NewsReplies: 63Last Post: 23rd Feb 2014, 22:34 -
VLC and CDDB
By hech54 in forum ComputerReplies: 0Last Post: 10th Jun 2010, 09:10 -
Where is the VLC 'Log'?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2010, 12:28 -
Enconding problems: flickering, horizontal lines and choppiness
By F u r u y á in forum Video ConversionReplies: 13Last Post: 25th Jan 2008, 02:44 -
subtitles in vlc
By video_idiot in forum SubtitleReplies: 14Last Post: 21st Dec 2007, 02:23
