Hi All
Firstly i would like to say sorry if i've posted in the wrong section, i have been using VSO ConvertX for many years to convert Various file formats to DVD, but im just getting into Blu Ray now.
My first question is what program should i use if i have say a 3Gb avi file and i want to put menus etc on and burn it to Blu Ray?
Secondly what is the best program to use for Ripping a Blu Ray inc maybe taking parts out so it will fit on a 25GB disc?
Sorry for all the questions but i do hope some of you out there can point me in the right direction.
Pete![]()
Results 1 to 9 of 9
1. AVCHDCoder, MultiAVCHD, D2MP. BUt they aren't as easy as convertxtodvd.
2. Maybe BDRebuilder. -
What exactly is your goal for wanting to burn to BluRay? Are you looking to dump a bunch of movies on a single disc to save storage? Or do you have the impression that converting your AVI to BluRay will make it look better?
If you want to rip you either have to buy AnyDVD HD or DVDFab HD Decrypter. There's a free version of DVDFab that might meet your needs but do note that it trails the commercial release by 6 months so brand new releases by some studios may not rip until the free version gets updated enough.
It's not always easy to get it working the first time but the free BDRebuilder can shrink any rip down to single layer BluRay size and also can give you the movie only. It should meet your needs without having to edit anything. -
Thanks Baldrick thats a great start, what about DdvFab? would you recommend??
Pete -
Hi Jman98
No, i know that i wont make the quailty better but just by putting it on to Blu Ray but if ive downloaded a 3GB MKV file then converting to to dvd will reduce the quality, so i was thinking it would be better to convert it to Blu Ray to keep the quality, would that make sense?
Pete -
*** Now that you have read me, do some other things. ***
Converting to ANYTHING will reduce the quality. Even BluRay. If you are very careful when converting you won't notice it at all but some loss will be there even if you can't perceive it. I don't convert anything to BluRay but I think multiAVCHD and maybe some other tools have the ability to do some fairly benign encoding to get your source file into BluRay specs (not always necessary, depending on the source). You might look into multiAVCHD. It can also produce menus but try a burn to a re-writable BD disc first as some players are fussier than others about what multiAVCHD produces and you may have to play with some settings to get something your player likes. Finally I should warn that we had a recent discussion and multiAVCHD seems to have been abandoned by its creator. If you have questions to ask about specific settings someone here might be able to help but we'll be pretty limited in what help we can give on it.
Hi
Thanks for all your help & advice, seems like this is going to be more complicated than i first thought! still at least you guys are here for help & advice.
Cheers Pete
newbie blu ray question
By cividan in forum DVD & Blu-ray WritersReplies: 10Last Post: 16th Oct 2011, 20:22 -
Question about ripping blu ray?
By HIimHISH in forum Blu-ray RippingReplies: 1Last Post: 21st Apr 2011, 17:21 -
ripping Blu-ray using MakeMKV question
By andy99 in forum Blu-ray RippingReplies: 2Last Post: 7th Jul 2010, 11:23 -
Newbie Help ripping blu ray
By DravenJ in forum Blu-ray RippingReplies: 5Last Post: 8th Jun 2010, 08:50 -
Converting HDdvd o Blu-ray... Testing... Newbie !!!
By kulmagen in forum DVD RippingReplies: 3Last Post: 11th Feb 2008, 16:13
