I downloaded a movie which was in mp4 format, and it looked really good quality.
I put it into my dvd player thinking it would play, and it didnt so i used super dvd creator to onvert it into vob file. I don't know much on video conversions or burning, but i then burned it into dvd-rw and the quality was alot worse, the refresh rate also looked poor. Is there anything else i can do with the original mp4 file to make it play in my dvd player at the same quality?
I also noticed another film i downloaded was an avi file, (which should have played fine) in my dvd player like other discs ive burned, however, it doesnt.
I need some help on these matters on what to do. cheers
Results 1 to 9 of 9
So what format do i need to convert it to? What program should i use? Will it lose much quality converting it?
You've given no info about the source files. Are they high quality HD files? If they are, and you want to preserve the HD,
you'll need something like the WD Live.
Otherwise, If you want a disk that will play on a typical DVD player, use one of the programs' mentioned above. -
Basically it's a film i DOWNLOADED called 50 / 50. The file is a mp4, i burned it to dvd r using windows media player, and when i put it into the dvd player it wouldnt accept the file format.
However, i used super dvd creator to convert the mp4 to a vob file (pal), after doing so, i played it in my dvd player and the refresh rate was crap! If i use the programs mentioned in this thred, what file format will it convert it to, and how good will the quality be as i dont want it turning out as it did when it got converted to a vob file.
I used super dvd creator as i could make my own title menu page and chapters. -
why should anyone help with your warez video problems? buy the movie when it's released.
It's surprising how many of these newbies know nothing about forum etiquette.
Here's some friendly advice. Before you jump in and post, lurk for a while. Read the kinds of things
being talked about, and try to get a feel for the "culture" of the forum. This is true of all forums.
If you'd done that you would have seen that openly discussing pirated movies is a big no-no, and is
severely frowned upon.
Basically you made a big fool of yourself and you will not be taken seriously.
Sorry to be harsh.
Best software to convert VOB to mp4 or AVI, or AVI to MP4?
By 80zforever in forum DVD RippingReplies: 7Last Post: 18th May 2010, 12:32 -
From VOB to MP4, using the subtiltes of the VOB?
By risager in forum User guidesReplies: 2Last Post: 24th Mar 2010, 10:52 -
Conversion from VOB-File into a MP4 File stopps after 9 minutes...
By Fly Eagle in forum ffmpegX general discussionReplies: 2Last Post: 6th Aug 2009, 11:41 -
vob to mp4 help?
By jfish666 in forum ffmpegX general discussionReplies: 1Last Post: 22nd Feb 2009, 17:03 -
AVI to mp4 Freeware and VOB to mp4 Freeware
By saucedmike in forum Newbie / General discussionsReplies: 2Last Post: 1st Jan 2008, 01:44
