I have been unable to access certain sites I frequent for the past couple weeks. I tried clearing my cash but it did not work.
I keep getting the following message:
Unable to connect
Firefox can't establish a connection to the server
The site could be temporarily unavailable or too busy. Try again in a few
moments.
If you are unable to load any pages, check your computer's network
connection.
If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
I know these sites are up but for some reason they don't work for me. Any idea what I could do?
Results 1 to 13 of 13
It's a command line tool to see if the site is reachable.
Open up a command window and enter the command as shown. Change the site to the site you're having issues with.
Here's how it looks:
Pinging any-fp3-real.wa1.b.yahoo.com [98.137.149.56] with 32 bytes of data:
Reply from 98.137.149.56: bytes=32 time=21ms TTL=52
Reply from 98.137.149.56: bytes=32 time=18ms TTL=52
Reply from 98.137.149.56: bytes=32 time=19ms TTL=52
Ping statistics for 98.137.149.56:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 18ms, Maximum = 21ms, Average = 19ms
From this, you can see the latency in milliseconds, also the IP address of the site - 98.137.149.56 -
you run cmd.exe from the Run box, or set a shortcut on the desktop to cmd.exe.
Try this: http://www.downforeveryoneorjustme.com
Ping is mostly useless for this troubleshoot.
You need to tracert.
Read this: How to traceroute?Want my help? Ask here! (not via PM!)
That just tells you the box is up, and not blocking ICMP packets
To really tell is a web server is up and accepting connections is either connecting via a browser like you normally do or
telnet to port 80
telnet servername 80
type GET
and it should return something -
Well, don't put the cart before the horse.
First see if the server even responds.
If so, then see if web services are working.Want my help? Ask here! (not via PM!)
I have been using ping to check the sites availability but the one you share was new to me, seems interesting.
Your ISP DNS might also suck. Change to OpenDNS.
This website
By Will Hay in forum Off topicReplies: 24Last Post: 17th May 2013, 18:11 -
ISP problem - some website pages load, other website pages don't
By PartingShot in forum ComputerReplies: 15Last Post: 7th Sep 2012, 00:42 -
SVCD2DVD 2.5 Will Not Load
By Rower4VT in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 2nd Sep 2009, 14:25 -
DVD does not load
By joelson in forum Newbie / General discussionsReplies: 4Last Post: 26th Dec 2008, 10:23 -
Does this site load for you?
By lordsmurf in forum Off topicReplies: 3Last Post: 4th Dec 2008, 11:56
