Hi
I have two alternatives for capturing my 8mm home videos and was wondering which method would yield the best video capture.
1) ATI All-in-wonder
2) Honestech Vidbox via usb Virtualdub HuffyUV
Video quality is often a very subjective matter. What one person may find acceptable another might consider crap. What method works best for one person may not work best for another, and what works on one tape may not be the best for another.
In short, if you have multiple means available to you, try them, do some experiments with the settings etc and then use whatever you determine to be the best results for you. -
Which All-In-Wonder?
If Huffyuv is the goal, I'd vote for All-In-Wonder hardware over any USB device.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Recommend Capture card/stick pls
By jubbely2 in forum Capturing and VCRReplies: 5Last Post: 27th Oct 2010, 12:14 -
Recommend one good external capture device
By jranaudo in forum Capturing and VCRReplies: 1Last Post: 8th Jan 2010, 02:35 -
Can any one recommend a tv capture card?
By Stevet1972 in forum Video Streaming DownloadingReplies: 2Last Post: 19th Nov 2009, 06:08 -
Can anyone recommend a NTSC capture + video card based on this criteria?
By Rein Engel in forum Capturing and VCRReplies: 7Last Post: 5th Feb 2008, 07:25 -
Method of VHS Capture to DVD
By robjv1 in forum RestorationReplies: 15Last Post: 28th Nov 2007, 09:00
