I saw this program (SVP) mentioned on the CNET website (http://download.cnet.com/SmoothVideo-Project-SVP/3000-13632_4-75446994.html).
Then I looked at the product website and saw it's from Russia. I guess I'm a bit paranoid, but I decided to ask if anyone here has tried it. Thanks.
Results 1 to 9 of 9
Lenovo ThinkStation P520, Xeon W2135; Win10Pro x64, 64Gb RAM; RadeonPro WX7100W; NEC PA301W, NEC PA272W, and Eizo MX270W.
I have tried this and it is pretty good software. Takes all of the technical config out of everything and just works. You need a pretty good cpu and gpu though. If you have an okay gpu and cpu, it should do 720p pretty well. I have a laptop with a t7500 cpu dual core @ 2.2ghz, and 8700m gt gpu, and it handles 720p fine. Anything higher doesn't work so well. Hope this answers your question.
Russians mostly develop software for nuclear stations control, military, oil extraction, computer vision, robotics, social media monitoring, cryptography and voice other IP. That's what a 90% of software developers are involved in.
The niche of end user software is undeveloped in Russia and mostly filled with beginners or enthusiasts. Most often serious companies simply don't go into that area. There are exceptions though.
In 99% of anything related to codecs, you are dealing with FFMPEG based product. FFMPEG library does not relate to Russia, it is opensource project. The founder is Hungarian.Last edited by DuplicateVideoSearch; 22nd Sep 2012 at 09:16.
And to answer the question - yes I've tried it - it's pack of various tools and decoders you could collect them manually on Videohelp too !
"Smooth Video Project" is on Softpedia so I don't think there is something suspicious in it ...
P.S. Don't know why those trojans designed to destroy Iran's nuclear program are in my mind now ...
My "money shot" video project
By Asterra in forum AudioReplies: 13Last Post: 23rd Apr 2012, 20:13 -
Anyone familiar with "DVD Album"?
By Ronny G in forum Authoring (DVD)Replies: 2Last Post: 25th May 2011, 06:59 -
MacTheRipper - "Untitled Project" Subtitle on Ripped Results
By ramseytheii in forum MacReplies: 2Last Post: 17th Jan 2011, 13:56 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 18:45 -
The "convert a single VOB file to a DVD" project!! :)
By djdust in forum Authoring (DVD)Replies: 42Last Post: 23rd Feb 2008, 08:49
