i tried out 1.17 but i don't see custom video settings available like in v1.16.5 .. is there a way to change the b-frames parameter in 1.17.0 ?
i also noticed that it doesn't shutdown my computer when i set the option, after a job completes the pc stays on ...
is 1.17.0 buggy ?
sent via android
Results 1 to 18 of 18
does anyone know how i can adjust the bframes and other video settings in 1.17.0 ?
sent via android -
thanks .. its inconvenient for me to read thru that thread, can you tell me how i can get there using the gui rather than script ?
or i can add the line to the ini file for the profile im using if u can post exactly how i should enter it ....
with 1.16.5 it was straightforward creating a custom profile and changing the bframes in video settings, seems like things got shuffled around with 1.17.0 ...
sent via android -
i didnt realize u are the dev for ripbot ... many thanks to you for bringing ripbot to the community !
i messed with 1.17.0 some more and i see now that i would have to enter the bframes argument in the commands pane, is this correct ?
so i just have to add the line:
--brames 1
is this right ?
also, is there a bug with the shutdown option ? when i did my trial run, it didnt shutdown my computer when it finished the job. with 1.16.5 it shuts down no problem. i actually prefer a sleep option rather than shutdown ...
thanks
sent via android -
Update is herealso, is there a bug with the shutdown option ? when i did my trial run, it didnt shutdown my computer when it finished the job. with 1.16.5 it shuts down no problem. i actually prefer a sleep option rather than shutdown ...
http://forum.doom9.org/showthread.php?p=1552882#post1552882 -
i tested 1.17 further and it doesn't look ready for prime-time. spits an error after finishing an encode about the disk not in the drive. also doesn't shutdown the computer when the option is set. it also doesn't want to close when i try to close it.
on the bright side, the --bframes 1 setting i added to the profile works.
i'm going to stick with 1.16.5 unless some major changes in encoding speeds/performance would justify jumping to a newer version. -
update, i found the ripbot update files to fix misc issues with 1.17, it works fine now, but the updated files should be rolled into an updated version of ripbot ... otherwise ppl without the updated files will still have issues with 1.17.0
sent via android -
another question:
can i specify bitrates between the available presets ? say, i want 5120, or 7168 is that possible ? -
because with certain media i want something in between the bitrates available
posted via android -
that is what im asking, can i input the bitrate manually
posted via android
Ripbot problem please help
By XxL3tHaL LsDxX in forum Video ConversionReplies: 1Last Post: 18th Dec 2010, 00:42 -
Ripbot error
By Bazza-61 in forum Blu-ray RippingReplies: 5Last Post: 20th Oct 2010, 08:25 -
Ripbot with Coreavc
By sanosuke in forum Video ConversionReplies: 4Last Post: 11th May 2010, 07:45 -
RipBot v1.15.0?
By ajgoyt in forum Newbie / General discussionsReplies: 4Last Post: 3rd Mar 2010, 06:14 -
ripbot
By jonno232 in forum Video ConversionReplies: 1Last Post: 18th Mar 2008, 22:50
