Here's the thing:
I want to replace the face of the person in a video with the IMAGE of someone else's face.
I have both Photoshop and After Effects.
I do know about motion tracking, key-framing, masking etc.
But the problem is the perspective change of the persons head in the video.
i.e. the person in the video is moving his head from left to right.So, how do i show the change in perspective in the replaced image of the head?
Results 1 to 11 of 11
You can 't do a realistic job with this , because the source image is 2D photo (flat, planar) in 1 projection. Even if you used a 3D tracker / matchmover with a true 3D program, you need better source material , with multiple projections or images showing different perspectives -
Like mentioned above, it's not easy, but to answer your question, try pressing ALT or CTRL while you're resizing the photo.
Yes, but those are 2d mapped, you need UV mapping with 3d coordinates
http://en.wikipedia.org/wiki/UV_mapping
Or use 3D projection techniques
After Effects isn't the right tool for this because it's not true 3D (it has 3D space, but they are 2D layers in 3D space . It's really "2.5 D") . The motion trackers in AE are 2D, not 3D. Even mocha is planar. You can use 3rd party 3d trackers (e.g. foundry camera tracker) , but it still integrates into AE with 2d layers in 3d space. In other words, you need your replacement photos of the "head", to be in near perfect alignment as the source "head"
You manually try to fake it in AE, by adding small adjustments distortions, with motion tracking, but it won't look authentic (or it will takes weeks of fiddling) . If your replacement images are in perfect aligment, then it makes it easier. But if you only have left, front, right and nothing in between, you are missing a lot of dataLast edited by poisondeathray; 10th Jan 2012 at 11:31.
Faking 3D can only be attempted when the object has "bilateral symmetry", and you're on a "normal" viewing angle, as in straight on at the same elevation.
What you do is make a copy of the image and rotate the copy 180 degrees, then bring both objects together so they bisect in the middle forming an "X" if you were to look down on them.
Then when you rotate the camera, there will be a rough 3D effect. This is useful for like trees that are in the background.
But since the face is going to get watched closely, it's not going to look realistic at all. -
Thanks for the advice.
I will just work my way around inside of after effects(as im not that good in the 3D part) to get this work done because attaining realism in the replacement is not my motive as the video is going to be humorous. -
If you're not wanting it to look realistic, this is achieveable, but again the tools built in AE or mocha don't account for 3D rotation (they are 2D point , and planar tracker for mocha ) - so you end up having to manually do some roto work and manually adjusting some of the images
Funny is good - Do you remember those "this is sparta" youtube videos ? hilarious
Yes, more manual work unfortunately. Good luck.
Post a link your finished video!
remove a spot of light from the face
By bobpete in forum Newbie / General discussionsReplies: 7Last Post: 10th Aug 2009, 19:39 -
Keep an Eye on Video Monkey, VisualHub's replacement.
By terryj in forum MacReplies: 3Last Post: 30th Jul 2009, 00:16 -
With which software can I censore somebody's face on a video?
By szalaikornel in forum EditingReplies: 7Last Post: 14th Feb 2009, 14:17 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 12:57 -
video of break in, can't see face
By minidrag in forum RestorationReplies: 20Last Post: 5th Nov 2008, 19:17
