I am currently using a Panasonic GS300. It has been great but now it's time to upgrade.
What I'm looking for is a camera that can output to IEEE 1394 & Composite and take take mini-jack microphone input at the same time. Zoom is probably the only thing that I would need to do image wise. It does not need to capture to tape or hard drive. I capture directly into the computer using WinDV (One of the best, easiest and consistent programs I've ever used).
I have done some research and googleing, but it's hard to tell if the IEEE 1394 & Composite output at the same time and that the microphone doesn't require some special or weird connector.
Does anybody have any suggestions??
Thanks,
~Donavon
Results 1 to 1 of 1
My IEEE 1394 cable can't be detected
By edhani in forum Capturing and VCRReplies: 1Last Post: 14th Jul 2011, 07:19 -
IEEE 1394 card
By beavereater in forum ComputerReplies: 1Last Post: 21st Jun 2011, 04:28 -
IEEE 1394/MS DV ERROR
By sampatman in forum Capturing and VCRReplies: 1Last Post: 12th Feb 2010, 10:54 -
Problem capturing using IEEE 1394 and camcorder
By Shabaman in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 22nd Aug 2008, 07:04 -
is the IEEE 1394 Adapter port necessary...
By roochie in forum MediaReplies: 15Last Post: 15th May 2007, 19:03
