I just got a new (to me) camera and this is the first time I'm trying to edit video with it. I have it connected via firewire..(and I tried USB too)...It recognizes my camera but it says, "failed to get video from device" I tried rebooting my computer and that didn't work. I can't get any help from Avid/Pinnacle support because I can't find my disc. Any suggestions???? I've connected with firewire and USB also.
Please email me directly at tvcamgrl@aol.com
Thanks in advance
Marnie
it's a pro format cam - DVCpro HD. you will most likely need vegas pro11 or avid express pro. if you are using the p2 cards then get the pana p2 viewer software. if you only use it as an SD cam you can use the tape section as it only functions as a miniDV cam then and you could capture the tape using winDV.
do not put real email addresses in forums, your address will be scraped and you will end up with countless spam messages as it will be sold over and over. no one here will communicate in that fashion anyway, it defeats the purpose of an open forum.--
The HVX-200 is intended to be used in two modes.
1. DVCproHD format to P2 flash RAM. P2 cards can be read though PCMCIA card slots at the computer.
2. 720x480i DV format to MiniDV tape. These can be captured normally with Firewire (e.g. with WinDV).
DVCProHD files will be in Panasonic's version of the MXF wrapper. You will need compatible edit software. Among them are ...
Adobe Premiere Pro
Vegas Pro with Raylight plug-in
AVID Media Conposer.
Final Cut Pro for Mac.
You can also capture analog component or SDI with AJA Xena/Kona
http://www.aja.com/media_folder_web/AJA_whitepaper_DVCProHD_editing.pdfLast edited by edDV; 10th Jan 2012 at 16:07.
http://www.kiva.org/about
Vegas Movie Studio HD 9.0 and Importing .avi files.
By empressofbees in forum Newbie / General discussionsReplies: 3Last Post: 17th Jan 2012, 17:45 -
importing a DVD into VEGAS Studio
By lissow in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2008, 02:34 -
Panasonic AG-HVx200 & Azden WMS-PRO compatiblity????
By tbrambo in forum AudioReplies: 3Last Post: 24th Jan 2008, 20:33 -
Beeping on audio on Panasonic HVX200
By spandau in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2007, 23:29 -
Importing PAL into Pinnacle Studio 11
By yifan in forum Authoring (DVD)Replies: 1Last Post: 31st Jul 2007, 17:11
