I just purchased a new DVD player, a Panasonic DVD Blu-Ray PLayer Model SC-BTT270. Everything is working fine except I cant get video oto play on the TV. I can hear the audio of the DVD but cant see the picuture. I replaced my old DVD player and used the same cables that worked on it with the same configuration. I have a HDMI plugged into the DVD player going out to the HDMI3 port on the TV. Also, there is a red and white cable for audio from the DVD player to the Directv Box. This is the same setup I had before. I know I have to find the right source on the DVD player and/or the TV and I think that is my issue. However, I do not know which one to use, I have tried them all but still think my issue is with the source. Thanks to any and all that respond to what is probably a very simple issue for most of you. Thanks for your time. Scott
 What is the TV?
 Why is that?Also, there is a red and white cable for audio from the DVD player to the Directv Box.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Make very detailed note of where everything is plugged in right now. Then, unplug EVERYTHING. Then, plug ONLY the HDMI out from the DVD player to an HDMI in on the TV. Set the TV input for that HDMI choice.
 If it doesn't work, it's either a problem with that TV slot (so choose another HDMI slot and try again), or with the cable or with the DVD player. If you've used the cable successfully before, it could be the player (unless there's some setup that you're supposed to go through to enable HDMI as the output default...).
 Something tells me you didn't have such a simple setup, though, if you were sending Audio from the DVD player through to the DirectTV box...
	Check the HDMI plug, my HDMI plug in back of my DTV box gets easily moved. This causes problems with the pi not being seen. It Started In Texas
	The TV is a flat screen Visio. I will check the actual model when I get home and add it to this thread. Thanks for the responses, I will follow through with the advice and see what happens.
	You don't need the red/white audio cables. HDMI carries audio. The fact that you're hearing audio but not seeing video makes me suspect you have the wrong input selected on the TV. Ie, you have HDMI3 selected on the TV but the cable plugged into HDMI2. Something like that.
  Video on my dvd playerBy moonshadow in forum DVD & Blu-ray RecordersReplies: 6Last Post: 24th Feb 2012, 17:41
  Looking for a Good Video Player Or DVD PlayerBy DJboutit in forum Portable VideoReplies: 1Last Post: 6th Jun 2009, 22:57
  Video all wacky on my DVD PlayerBy kelemvor in forum DVD RippingReplies: 1Last Post: 13th Jan 2008, 18:56
  Dark video on DVD playerBy ckamc in forum Newbie / General discussionsReplies: 2Last Post: 1st Nov 2007, 13:56
  How Can I Convert Real Player Video Files To Make Them DVD Player CompatablBy Lennoxtown in forum Video ConversionReplies: 8Last Post: 17th Oct 2007, 07:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
