Hi
I'm a paranormal investigator.
On some investigations we use locked of video camers to laptops to reacord for hours and hours.
What I'm looking for is some software that will analyse if there is any movement in he video saving us to watch hundreds of hours of footage.
Once found any movement to log the timming?
cheers In advance
Craig
	Security cam software uses motion detection algorithms. This can be tricky with high noise source particularly IR illumination with cheap IR cameras. It all comes down to signal to noise to reduce error rates. To increase S/N one must add illumination or invest in a more sensitive camera. Even so, bugs or blowing dust may create false triggers.
 Assuming ghosts exist, what makes you think ghosts respond to a particular narrow IR light spectrum?Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
  New camera, trying to figure out how to use footage from itBy Nilfennasion in forum MacReplies: 1Last Post: 26th May 2009, 09:08
  1CCD camera capturing 3ccd footageBy ninjagaiden in forum Capturing and VCRReplies: 1Last Post: 9th Nov 2008, 21:17
  Here's a Doozie: Security Camera footage.By RiverOtter in forum Capturing and VCRReplies: 25Last Post: 10th Dec 2007, 16:40
  Footage shot in DV mode on an HD camera. HelpBy lafsunlmtd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 6th Sep 2007, 17:11
  Capturing camera footage using VideoStudioBy markannab in forum Capturing and VCRReplies: 1Last Post: 9th Jun 2007, 02:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
