I've got this mkv file:
I used mkvextract to convert to a .h264 and .mp3 file, then tsMuxer to convert the .h264 file to an M2TS file, then imported into Encore. The audio, however, cuts off a few minutes before the end of the video. It's fine in the original mkv, and the mp3 and M2TS file appear to be in sync.General
Format : Matroska
Format version : Version 2
File size : 4.46 GiB
Duration : 2h 44mn
Overall bit rate : 3 895 Kbps
Encoded date : UTC 2009-04-29 21:59:18
Writing application : mkvmerge v2.7.0 ('Do It Again') built on Apr 15 2009 00:27:10
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 2h 44mn
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : A_MPEG/L3
Codec ID/Hint : MP3
Duration : 2h 44mn
Bit rate mode : Variable
Channel(s) : 1 channel
Sampling rate : 44.1 KHz
Compression mode : Lossy
Delay relative to video : 1ms
How can I get the last few minutes of audio?
Results 1 to 1 of 1
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Convert MKV with ACC audio to AC3 audio for PS3 playback
By wolvie77 in forum Video ConversionReplies: 4Last Post: 25th May 2010, 11:13 -
Convert from MKV and keep subtitles / audio.
By Alchey in forum Video ConversionReplies: 1Last Post: 10th Oct 2009, 03:45 -
how to convert audio in a mkv
By tomrip in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2009, 04:29 -
Convert MKV's audio on Mac
By frosse in forum MacReplies: 9Last Post: 28th Feb 2008, 19:09
