My sis-in-law's computer has 5 bad capacitors and won't boot any more. Other than that it is a really great machine. I have heard vague rumors of services that will replace caps if I pull the mobo and send it to them. I have replaced caps on my LCD TV, but these are a lot smaller and I am a bit nervous about it. Has anyone used a service to replace caps that he can recommend?
Just in case anyone is interested, I found a pretty reputable place: http://www.badcaps.net/ In any event, its a good read and he even tutorials how to do it yourself.
Honestly, at a minimum of $85 a motherboard I would find a board on Ebay that uses your processor/memory and coax a few more years out of an old system.
Personally, I would consider it a sign from the motherboard gods that I need to upgrade my stuff.
It is an interesting site though.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Thanks for the reply, I understand your point of view. This was a high-end unit that was fast and stable, with a high-end video card (for that time). Yes, I could save a few bucks and take a chance with E-Bay. For a few bucks more I know for sure what is wrong with this board will be fixed and I donīt know anything about one I would buy from an unknown person. I would really like to replace the caps myself, would be a fun project. However, I have an immediate need for this unit and would rather experiment with a less valuable one later. Thanks...
GOOD LUCK with your DIY repair... Hope you have better luck with me...
Even if you fixed the 5 bad capacitors, you would never know if the damage went beyond just those electric components....
Worst comes to worst when the damage reaches the chipset ,bios, CPU, etc...
I had a similar experience... with just 3 bad capacitors on my MOBO and lost pratically VIDEO, AUDIO, LAN... After replaceing the busted CAPS, VIDEO, AUDIO, LAN were still whacked out. I also invested in separate cards just to replace what was lost on the on-board... After 6 months of use as a server (on 24/7) , the BOARD was dead.... and took with it the brand new HARD DISK which was connected to it.
I eventually bought a more PC to replace it and I never looked backed at the loss...
I guess we should not get attached with what we have... heheh. PC are never exceptions to MURPHY"S LAW ["If anything can go wrong, it will"] ... They all break down at some point in time. -
caps are cheap .I bought good brand name from digikey.com .give it a try.nothing to loose sice u have a dead motherboard anyways
I got few tips from this site
http://www.badcaps.net/forum/ -
I replace bad caps on mobos now and then. I may or may not get money out of it
. All major electrolytic caps on a mobo have to be replaced, not just the ones that appear bulged. http://www.badcaps.net/ mean well, but as I have experienced, showing people (even some electronic professionals) how to do it is hit-or-miss. This is a delicate job whose finer points can only be honed from having done it hundreds, if not thousands of times; not on your precious mobo for the 1st time anyway. I personally can get by on my 0.8mm tip controlled iron and solder braid with 60/40 or 97/3 Pb-free; some have to go the whole hog and use a dedicated desoldering station. Some can just about burn and butcher the mobo any way they approach it, so I have to do it instead. Then there is the matter of in about 5% of the cases, there is damage other than the bad caps themselves (assuming they were correctly replaced) that still prevent the wretched mobo from booting. Good sleuthing and troubleshooting techniques, with a handy magnifying glass can sometimes save the day (cold-soldered connectors, etc), but if still not successful, at some point, you have to consider getting a new x79 mobo
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Which is better - usb stick vhs cap or hd-pvr cap + convert for vhs to dvd?
By yoda313 in forum Capturing and VCRReplies: 22Last Post: 22nd Dec 2011, 20:13 -
Pioneer DVR-433H Burner drive replacement - HDD Replacement 750GB succesful
By linkox in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Dec 2008, 11:57 -
Dual Core or single does it really matter for captures. Which mainboard?
By gll99 in forum ComputerReplies: 114Last Post: 16th Aug 2008, 17:16 -
Temporal References in GOP#9733(Zer-Based)are out of sequence(0xc10b000a)?!
By Bruxo in forum Authoring (DVD)Replies: 0Last Post: 27th Jan 2008, 21:34 -
Book or web references on computer programming for DVDs?
By newbee51 in forum ProgrammingReplies: 2Last Post: 30th May 2007, 19:09
